350 SBC to 400 SBC
Old Apr 19, 2021 | 10:25 AM
Brannon's Avatar
Brannon
Default 350 SBC to 400 SBC
I've ordered a 400CI from BluePrint Engines to replace the GM 350 Crate engine already in the car (it was already in the car when I bought it). I purchased the fully dressed long block (carb down to oil pan), link below to the part #, specs and what it comes with.
https://blueprintengines.com/product...tor-bp4002ctc1
I have a 1980. It was an original 4spd manual car, but now has a Richmond 6spd manual mated to the GM 350 crate engine.
I'm pretty sure all my accessories will mate over, but I called BluePrint to confirm. They also expect they will as well. With that said, neither they nor I are experts on 1980 Corvettes. So, I'm reaching out to the many on this forum that are experts on late model C3's and engine swaps.
I'm going to shore up the drive line post swap. Due to volume, they are about 10 weeks out on delivering my engine. In the interim, I'm going to get prepared for its arrival. The BluePrint guy said I probably won't need to replace the fuel pump, but these are the kind of things I'm relying on the forum members for direction.
What supporting parts/accessories would be recommended by the members here to the most out of my new engine?
Old Apr 19, 2021 | 11:22 AM
Gale Banks 80''s Avatar
Gale Banks 80'
As long as the 400 is internally balanced there shouldn't be really anything different at all. Its not really an engine swap more of an engine change.
Old Apr 19, 2021 | 11:37 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
While your at it, an aluminium rad and a programmable MSD ignition box? Also a 180*F thermostat and reuse the fuel pump, alternator, fan setup. A 1-3/4" drop base air cleaner and the tallest air filter you can fit under the hood.
Old Apr 19, 2021 | 12:52 PM
drwet's Avatar
drwet
Several potential issues come to mind:
- The new engine is externally balanced at the rear - you will need a new flywheel with the appropriate balance. You will need one anyway if your previous engine was not a one piece rear main seal
- The new engine has a passenger side dipstick. I believer the '80 originally came with a driver side dipstick. Not sure what you plan to use for an oil pan but might be an issue for you. Also I can't tell from the website whether the engine is actually supplied with the stick and tube, but if not, you will need them.
- The new engine is 'tapped for clutch linkage'. There are a couple of different locations for the hole for the clutch linkage. Need to make sure it is in the right spot.
- You may have hood clearance issues with the intake manifold supplied with the engine. Our cars are notoriously tight in that area.
This list is by no means complete, just those things that come to mind based on my personal experience.
Old Apr 19, 2021 | 01:25 PM
kossuth's Avatar
kossuth
Personally I would consider a long block. As was mentioned intake clearance is pretty tight. Are you sure the oil pan they are providing will fit the C-3 chassis?
Might make more sense to pickup the intake, carb, and dizzy all separately
Old Apr 19, 2021 | 05:22 PM
Brannon's Avatar
Brannon
Thanks drwet.
- My current crate engine is a one piece rear main seal
- The current crate engine has the dipstick on the passenger side as well. If need be, I should be able to use the oil pan on the current crate engine.
- Understood, I'm hoping that it's GM small block that the tap is in the same spot. I'll have to follow-up on that.
- I have an L88 hood rise grafted in the 1980 stock hood, so there's some more clearance. Hopefully it's enough, so I don't have to mess with the intake.
Old Apr 19, 2021 | 05:55 PM
derekderek's Avatar
derekderek
flywheel. absolutely. blueprint site says internal front, external rear. 1 piece 350 flywheels are SLIGHTLY external balanced. stock 400 (2-piece) is HEAVILY external balanced. you have 10 week lead time. ask blueprint to provide you with the correct flywheel that they balance with the rotating assembly. if they say it is the same balance as 1-piece 350, ask them to get a new flywheel and balance it with the rotating assy anyway.
Old Apr 19, 2021 | 07:19 PM
Brannon's Avatar
Brannon
Thanks Derek,
I will paste this on an email to them accordingly.
Old Apr 20, 2021 | 06:28 AM
Bikespace's Avatar
Bikespace
Old Apr 20, 2021 | 10:52 PM
CColosimo's Avatar
CColosimo
Small world...I too purchased the fully dressed 400 from BluePrint (order placed on 4/8, 10 week eta). I am mating it to the t56 that is currently in my 79, and the 400 will be replacing the current 350 (2 piece rms 350) w/ vortec heads and xe268 cam.
I worked with Josh on the BluePrint sales team and have their tech team on speed dial to make sure all my questions are answered
Good guidance provided by other members thus far, and here is my own (growing) list of supporting upgrades...
Reusing:
- Dewitts radiator/fans.
- Serpentine setup/accessories.
- Reverse flow waterpump.
- Starter (153 tooth).
- T56.
- Drop base air cleaner.
Replacing:
- Flywheel (1 piece rms).
- Clutch/slave/pilot (leaning towards McLeod rst).
- Motor mounts (short and wide style).
- Fuel pump (unknown age of current).
Have you chosen a clutch yet? Curious on what you’re leaning towards.
Also, I noticed that BluePrint increased their price from $5699 (what I paid on 4/8) to $6099 (current price in link). Hopefully you paid the lesser but if not, I’m happy to send you a screen shot of my invoice if you think it’ll help knock a few bucks back in your wallet.
Best of luck and looking forward to following this thread and your progress on the swap.
Cheers,
Chris
Old Apr 21, 2021 | 08:39 AM
Brannon's Avatar
Brannon
Reusing:
- T56.
Replacing:
Cheers,
Chris
Thanks Chris, good to have a partner in crime. Thanks for the list. Looks like we ordered a week apart. I'm eager to track your progress a week ahead.
I was able to get mine in at the $5,699 as well.
Also Reusing:
- Richmond 6spd
- McLeod clutch
Replacing
- I sent an email to BluePrint, response to derekderek's reply, regarding the flywheel used to balance at BluePrint. I should hear back today.
- Motor mounts - haven't thought about replacing the motor mounts. What are your thoughts on this?
- Thinking about the fuel pump. I need to go through the list, again, of the all the parts the previous owner replace. He performed a pretty thorough restoration.
- Thinking about an electric fan setup as well.
- Also thinking of moving to a full serpentine drive setup.
I have less than 1K miles on my current GM 350 crate engine. Hopefully, I can recover a few cost selling it after the fact.
Old Apr 21, 2021 | 10:12 AM
gkull's Avatar
gkull
I would be concerned with the 1980 differential going to a 400 with 500 hp
Old Apr 21, 2021 | 10:13 AM
derekderek's Avatar
derekderek
CCol; 153 tooth flywheel? they sell 153 tooth 1 piece flywheels. they all say ext balance. for all we know, blueprint balances their 400 to the 350 1 piece flywheel. but you need to KNOW that. get in touch with blueprint and discuss it with them. https://www.summitracing.com/search/...-style/1-piece
Old Apr 21, 2021 | 11:57 AM
jim-81's Avatar
jim-81
Yeah, gonna have to baby it a little ... or let it rip and replace it if it breaks.
Old Apr 21, 2021 | 12:36 PM
Brannon's Avatar
Brannon
Derek,
I reached out to BluePrint regarding the flywheel. Here is how it posed my question "As I have an up to 10 week lead time, awaiting my BluePrint 400CI (BP4002CTC) to be built and delivered, I’m trying to get all my ducks in a row. I’d like to be plug and play when it arrives. I currently have an aftermarket GM performance 350CI crate engine in my restored 1980 Corvette. It’s mated to a Richmond 6spd manual. The current engine has a one piece rear main seal and the dipstick is on the passenger side. I posted a few questions on the Corvette forum in the C3 section seeking advice from those that might give direction to things I might not have thought of and prepared for regarding any additional parts needed. Attached is one response I received that I felt was important to ask. The advice I’m getting is to get the flywheel BluePrint used to balance with the rotating assembly (See attached screenshot). What is BluePrint’s advice in this matter" This is their response "Thank you for the information, I greatly appreciate it. We would we recommend a flywheel that is weighted for a one piece rear main seal. You can these recommendations on our website. The direct link to the recommendations is https://blueprintengines.com/product...tor-bp4002ctc1. If you have any other questions, feel free to reach out to us."
They keep saying I need a flywheel weighted for a one piece rear main seal. I already have a one piece rear main seal. Thoughts?
Old Apr 21, 2021 | 12:40 PM
Brannon's Avatar
Brannon
I agree completely. I'll be upgrading the drivetrain as well, after the engine is in. As jim-81 said, I'll have to baby it a little until then.
Old Apr 21, 2021 | 12:52 PM
Catfish4818's Avatar
Catfish4818
Brannon,
Scrolling down to the lower part of the webpage that their link directs you to, they have a listing of recommended parts, and it shows two different ring gear/flex plates, both for one-piece main seal applications. Is this the info you're looking for?:
https://blueprintengines.com/product...-sfi-bpp871006
https://blueprintengines.com/product...-sfi-bpp399173
To 350 SBC to 400 SBC
Old Apr 21, 2021 | 01:00 PM
derekderek's Avatar
derekderek
it sounds like they are saying they balance this rotating assy to the one piece 350 flywheel and flex plate. it IS after all the only one that fits this crank. but i still would like to hear them say that in so many words... okay, i called blueprint. they said so in so many words. they balance this rotating assy with a STOCK chevy 1-piece 350 flywheel.
Old Apr 21, 2021 | 01:09 PM
Brannon's Avatar
Brannon
I'll see if I can get them to be more specific. With that said, as mine is already a one piece rear main seal, I shouldn't need theirs, if the above it true.....correct?
Old Apr 21, 2021 | 02:21 PM
CColosimo's Avatar
CColosimo
derekderek beat me to it...I called BP as well and confirmed the above. Brannon, you should be able to use your current 350 1-piece RMS flywheel without issue.
