Fuel filter question
Old May 1, 2021 | 09:00 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Default Fuel filter question
Can someone explain the workings of this fuel filter? This is the second time I've seen this.
Is it for emissions? Sorry for the small pic. It sits in front of the engine verticly and has 2 lines running into the top.
Old May 1, 2021 | 09:39 PM
kodpkd's Avatar
kodpkd
I really can't see the pic,, but from your description it sounds like an original fuel filter. There are two functions of the filter,,,, 1. to filter the fuel. 2. to assist as a fuel return line. Number 2 being most important. I had lots of hot fuel issues with the car not starting. I hooked the original filter and fuel return line and haven't had an issue since. GM knew what they were doing in 1968.
Old May 2, 2021 | 09:05 AM
Mooser's Avatar
Mooser
Any idea what year the car is? The image is a tiny thumbnail
Are you talking this type of setup?
if so then as kodpkd says it's the return
M
Old May 2, 2021 | 01:06 PM
0311 jarhead
M
Thats it. The first time I saw it I thought it was jerry rigged. The second time I figured it was factory, I've owned a few C3's but never saw this setup before.
Thanks for the info
Old May 2, 2021 | 01:28 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
There is supposed to be a bracket clamp around the filter that bolts to the AIR pump mount
Old May 3, 2021 | 11:13 AM
kodpkd's Avatar
kodpkd
I also tried to get a bracket to work. Easier said than done.
Old May 3, 2021 | 11:22 AM
ralphspears
Banned Scam/Spammer
Do you have a bracket ? do you have the AIR pump on the engine ?
Old May 3, 2021 | 12:20 PM
kodpkd's Avatar
kodpkd
I made a bracket like the stock one. My issue is with the fuel lines. If I redo the fuel lines it would fit. Maybe next winter. Mine is a 68, no air pump.
To Fuel filter question
