Blinking/Flickering headlights
https://www.corvetteforum.com/forums/c3-tech-performance/3727033-fuses-for-a-1973-a.html
My headlights open and work fine when starting cold, but after 10 minutes or so on the road, they start flickering / blinking on and off.
Garage missed this since it looks fine if you just start the car for a quick look.
Any ideas what could cause this?
Any input very much appreciated!
Good news, it's an easy fix. Just add a pair of headlight relays to your underhood wiring, reasonably close to the alternator, like all newer cars have. This will take the load off your vintage wiring and your headlamps will be much brighter.
I do this simple and inexpensive upgrade to all my vintage cars.
cars. Only takes about 20-30 minutes. For the procedure, just do a search here for "headlight relays".
Cheers, Greg
Reproduction headlight switching on/off circuit breaker is a known issue.
The fix is as Greg said- headlight relays- replacing headlights will not solve the problem.
Here's a test- the "new" Halogen bulbs actually pull less current-
Bosch 332019150 RockAuto has them for less $2- made in Portugal- not Chinah
https://www.rockauto.com/en/parts/bo...ing+relay,3380
It is a 5pin relay- but it has TWO output terminals-
Makes wiring soooo much easier.
I use 12GA for power- under the hood with the extra heat- going up a size is a rule of thumb
For circuit protection- you might wanna stay away from fuses- unless they are easy to replace at night-
The LED fuses- light up when they blow would be a great choice.
I also like the combo relay/ fuse block-
https://www.autoelectricsupplies.co....01/category/37
And if you have fiberoptics- Delcity sells a female plug that has the fiber optic cavity
https://www.delcity.net/store/Headli...98105.h_818652
Here's a clean way to use three relays- each headlight has its own terminal- simplifies wiring
Here's my diagram and I use the Bussman self resetting CB.
Are the headlights stock? If you dont know how about a picture of the headlights? Sounds like you just bought this car from a garage? If so there could be anything going on from the previous owner as well as just a dirty wiring connection or faulty headlight switch.
As mentioned the stock wiring on these cars was not the ideal setup but if if its blinking and cutting out you may want to find out why first instead of just installing the relays which may or may not resolve the issue but for how long? If the switch is starting to fail its probably best to replace it... but first I would start with checking and reseating the connections to it. as well as your ground to the headlights.
Now, if that points style contact gets welded closed you've just lost all your current control in this circuit and since it doesn't have a fuse or anything the next thing to control the current it the wires or the headlight switch starts to heat up and burn. A loose ground could cause the light to flicker too but to me that is highly unlikely.
This is the reason for relays. The relay mod does a number of things but the most important IMO is getting that high current draw out of the headlight switch and out of the passenger compartment. The second best thing is now all the voltage coming from the alternator (in my case 14+ volts) goes directly to the headlamps which increases the brightness.
One word of caution, don't just install relays using the existing forward headlight harness. The wire gauge is too small to handle the increased voltage which will cause the wire to get hot and potentially catch fire as in the original scenario.
I just bought the car from a private seller, who didn't make the best impression (handed me a bottle of water "just in case", 20 minutes later I was stuck on the motorway with a dead 'vette...), so I'll be going over everything as I get to it. Most important is the flickering lights, since driving lights are mandatory here, and I don't think the fuzz will be happy with my "blinking" kind.
What you describe here with the two metals heating and cooling, would that happen quick enough for the lights to blink several times per second? Heating probably could happen very fast, but not sure metal would cool down that quick...
I'll get some pictures of the headlights (I don't know whether they are original, but previous owners changed all kinds of things, including paint (yellow->black) and engine, so I wouldn't be surprised if the headlights are aftermarket too.
I was hoping to make a video of what I mean by blinking/flickering, since I realize that is very vague...
Does your light start flickering just sitting in the driveway without moving? If so I'd rule out a loose ground as one would think it would only happen while driving around hitting bumps etc.
Good luck with your project. There are many members here that have a lot of knowledge about these cars so don't hesitate to ask anything.
My father once said "The only dumb question is the question you do not ask". Wise Man - R.I.P
You can get a pre-made male 3 pin plug - (yellow one in pic) or you can make your own.
Plug it into the low beam plug- you'll get a hi/low and a ground- which will work great to control the relays.
You can tuck the relays up under the front of the nose- and get your power from the horn relay or alternator.
Adding additional devices- like fans (which easily pull more than triple the power of what the low beams pull) to the stock system's capacities- I can't recommend connecting those to the alternator.
Richard
Corvette 1973 Headlights
Not sure if you can tell from these pictures whether they are new?
I put some videos up here:
http://molk.ch/fun/corvette/1973/vid...hts-inside.mp4
http://molk.ch/fun/corvette/1973/vid...ts-outside.mp4
But reading this thread (and also the owner's manual...), it seems clear that relays will probably fix it.
The diagrams are very nice, but how do I find out exactly which wires to mess with on the car? I've checked my fusebox (which is irrelevant if I understood correctly), and of course I know where I put my foot to put the lights on, but how do I get to where the relays need to be installed?
I have the haynes manual, and some other books I can check, but maybe this is not as hard as it seems?
I have an experienced mechanic I can get to help with this, but I would like to understand what we'll be doing before diving in.
Thanks!
