Rocker Panel Removal
Old May 5, 2021 | 09:23 AM
Floydy's Avatar
Floydy
Default Rocker Panel Removal
Hello,
Does anyone know if the rocker panels need to be removed in order to lift the body off the frame a few inches on a 1980?
I'm doing body mounts and plan to the lift the body a few inches one side at a time. Through this forum I've got a pretty good overview of what needs to be detached between body and frame but the later C3's were different to earlier generation (a lot of the advice here is early '70's) and it's unclear about the rocker panels on an '80.
(Note that I'm referring to the rocker panel not the rocker covers)
Thank you in advance!
Old May 6, 2021 | 01:18 PM
c3corvettes's Avatar
c3corvettes
I don't believe you have to remove them for your project. I'll be anticipating replies from the experts along with you, as I too want to replace all of the body mounts on my '80.
Old May 6, 2021 | 02:40 PM
lakerider57's Avatar
lakerider57
No, you don't have to remove them. I did a complete frame-off on my 1980.
Richard
Old May 6, 2021 | 06:50 PM
Floydy's Avatar
Floydy
Thank you. I plan to document the work this weekend, if there is anything I can do to help you let me know.
Old May 6, 2021 | 06:53 PM
Floydy's Avatar
Floydy
Richard
Thanks Richard, much appreciated. Would it be pushing the friendship to ask if you removed your front and rear bumper covers? I will likely remove the front bumper cover as it will make it easer to rebuild the headlights and clean up the valance/air dam. Maybe loosen the rear?
Old May 6, 2021 | 07:01 PM
derekderek's Avatar
derekderek
no, the rockers come out after you take the body off. and the nose off, and the cowl off, and the windshield frame off...
To Rocker Panel Removal
