1980 BW 4 speed overhaul (Help please)
Old May 15, 2021 | 05:56 PM
rmrtrex's Avatar
rmrtrex
Default 1980 BW 4 speed overhaul (Help please)
Good Evening all,
After 3 weeks of waiting for my Borg Warner overhaul kit for my tranny, last Wednesday I was able to take my car in to tranny mechanic to get it worked on. Today(Saturday) I get a call from the mechanic and he says car is ready but now is does a weird shake when the clutch is engaged. Mechanic says there is probably something wrong with the engine. I told him no, why does this only happen when I engage the clutch? I am sorry but I can't leave with the car when it is acting like this, I am afraid it might cause some damage to my engine.
Sorry I said all that to get to this: The car had all the gaskets and synchro's replaced and mechanic said go buy the clutch, pressure plate, and that he would resurface the flywheel. I was fortunate that O'reillys had them in stock. There was a heavy duty package and a standard package. I opted for the HD package. Below is a picture of original alongside the new HD one. The are both 11" except one pops out a little more in the center than the other. What could be causing this erratic shake?
This is the original alongside new replacement. Should I be worried about center pop up sleeve? Could that be what is causing the erratic shake?
Old May 15, 2021 | 06:11 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Mechanic rebuilds tranny & clutch assembly and now claims engine is bad???? Maybe the mechanic is bad.
Old May 15, 2021 | 06:13 PM
interpon's Avatar
interpon
That clutch does not look right ..not even the friction area
is it vibrating when clutch out in neutral? Could be input bearing..
here is my journey
https://www.corvetteforum.com/forums...r-etc-diy.html
Old May 15, 2021 | 06:21 PM
derekderek's Avatar
derekderek
friction surface is skinnier on new clutch disk. is pressure plate clamp ring similarly smaller? if so i would not call it heavy duty. sounds more like a cheap-out. post pics of pressure plates and other side of disks. i think you need a new trans mech. clutch does not look bad, and i assume it did not act like that before tbhe trans work? i hope you haven't paid him yet, cuz i think somebody else needs to go through that trans.
http://www.quotesmeme.com/wp-content...43654018_n.jpg
Old May 15, 2021 | 07:36 PM
rmrtrex's Avatar
rmrtrex
It only vibrates when I engage the clutch.
Old May 15, 2021 | 07:37 PM
rmrtrex's Avatar
rmrtrex
In neutral no vibration at all.
Old May 15, 2021 | 07:41 PM
interpon's Avatar
interpon
Just to be clear...you say engage clutch..that is with pedal up and foot off...and in neutral no vibration..
then you push clutch in to disengage and it vibrates?
this is a good read
https://www.knowyourparts.com/techni...s-replacement/
Old May 15, 2021 | 08:11 PM
stingr69's Avatar
stingr69
Might be a broken drivers side motor mount. You cant tell just by looking. You need to unbolt it and remove to check it.
Old May 15, 2021 | 08:49 PM
rmrtrex's Avatar
rmrtrex
My bad, when I push pedal in is when it vibrates.
Old May 15, 2021 | 08:52 PM
interpon's Avatar
interpon
could be throwout bearing, or pilot bushing
read that article and tell which it is for you..Pilot Bushings and Bearings
To check for a noisy pilot bushing, begin listening for noise after starting the engine. Listen for noise with the engine running, the transmission in gear, and the clutch pedal to the floor. The clutch is released, but the transmission is in gear, which causes the engine crankshaft to spin around the held transmission input shaft. Noise under these conditions indicates a worn pilot bushing or bearing, or a worn release bearing.
To isolate the pilot bushing or bearing from the release bearing, keep the clutch pedal on the floor and shift the transmission into neutral. If the noise persists, the release bearing is defective since the input shaft is now free to rotate. A bearing noise that occurs if you release the pedal to engage the clutch while in neutral, but goes away when the pedal is depressed, is caused by a defect on the transmission’s input shaft bearing.
Old May 15, 2021 | 08:54 PM
derekderek's Avatar
derekderek
then throwout bearing is most likely culprit. at least a place to start. check that clutch lever in bell housing is seated on the ball correctly. it is not the clutch itself unless it vibrates as you let off the clutch to pull out.vibrating as ytou engage clutch is that symptom.
Old May 15, 2021 | 09:07 PM
interpon's Avatar
interpon
My clutch looked like this and didn’t vibrate...
lots of threads on clutch buying decisions..
personnally i would not buy that clutch..
here i got some good advice
https://www.corvetteforum.com/forums...se-79-l82.html
To 1980 BW 4 speed overhaul (Help please)
