HEI Distributor - Too Tall
Old May 16, 2021 | 08:06 PM
armstrrw's Avatar
armstrrw
Default HEI Distributor - Too Tall
I have just installed an electronic distributor in my 1971 ls5 to compliment a FiTech EFI system. The distributor with cap and wires installed (HEI) sit quite a bit higher than my original cable drive points distributor. I removed the plastic plug wires retainer and tried installing the distributor cover again and it still won't fit. Any suggestions how I can use the cover with the new, taller distributor? Is there some combination of HEI wires/boots that will work?
Old May 16, 2021 | 08:26 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
perhaps get the chrome covers for a 76 or 77? look much the same and definitely fit over the HEI.
Old May 16, 2021 | 08:27 PM
4-vettes's Avatar
4-vettes
Or perhaps extend your side brackets upwards a bit?
Old May 16, 2021 | 09:33 PM
augiedoggy's Avatar
augiedoggy
Years ago I found my 74 covers wouldnt fit after going to the larger Hei either so I always assumed that it was normal.
Old May 22, 2021 | 04:35 PM
armstrrw's Avatar
armstrrw
Since the plastic wire retaining cap won't be used, how about carefully trimming the pointed top off the distributor boots? I don't know if cutting off the boot top will expose the plug wire or clip. Anyone tried?
Sorry, I wasn't very clear. The plastic retainer has two screws that holds the wire boots onto the distributor cap. If I can get the older style boots or trimming off the top of the HEI wire boot, the chrome cover will fit so tight that it will hold the distributor boots in place ...... if this makes sense.
Bob
Old May 22, 2021 | 05:57 PM
4-vettes's Avatar
4-vettes
Sounds like it would work to me. I'd try trimming. if you goof em up, then plan B. buy wires without the tops on the distributor cap end.
Old May 22, 2021 | 07:15 PM
MelWff's Avatar
MelWff
If you are referring to the radio shield, why are you trying to reinstall it, do you listen to AM radio?
Old May 23, 2021 | 12:46 AM
4-vettes's Avatar
4-vettes
or maybe just cause they look nice.
To HEI Distributor - Too Tall
