1982 corvette fuel injector help
Old May 17, 2021 | 11:43 PM
Kacey1's Avatar
Kacey1
Default 1982 corvette fuel injector help
Hello, so I got an 82 with CFI. Ever since I got the car it’s been having troubles. One of those has been a constant slight missfire and it runs rough when warm and idling. I don’t get any codes and when I get up to speed, it does just fine.
I checked the injectors to see if there was any issues there. I saw that the rear injector (closest to the driver) has got these really small drips coming out of the injector head every time it pulses and it’s spraying alittle off.
do you think this could cause the missfire and running rough? I also thing the ignition coil may be bad which isn’t helping. I’ve redone the entire ignition system besides the coil
Old May 18, 2021 | 08:37 AM
Fly skids up!'s Avatar
Fly skids up!
Hard to say. It would depend on how bad the injector is dripping. But any drip is cause alone to replace or service the injectors.
Old May 18, 2021 | 08:45 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Two things...fuel and balance. Take a timing light and point it at the injector spray cone. You will be able to see how the injector spray pattern is looking and should be a nice even pattern. Could be a dirty injector or something else. Also, TB balance IS real important on these motors along with fuel pressure, FP should be at 13psi for maximum potential of the motor.
Old May 18, 2021 | 09:32 AM
Eric P's Avatar
Eric P
Does it drip if you cycle the fuel pump ? if it does the injector o-ring might be compromised
Old May 18, 2021 | 11:36 AM
Mrvettenick's Avatar
Mrvettenick
Get a scan tool to monitor block learn values. If the value is below 128, then the computer is cutting back on fuel to compensate for the drippy injector. In that case, all of the plugs might be darker than normal. If it's only one or 2 plugs, then I would lean to ignition like wires, or even a bad plug.
Old May 18, 2021 | 12:13 PM
Buccaneer's Avatar
Buccaneer
Which scanner does that for OBDI and monitors BLM?
Old May 18, 2021 | 12:24 PM
Eric P's Avatar
Eric P
the Snap On Brick , Pro Link and the GM scan tool all read Block learn . Block learn won't move on open loop but is active in closed loop , you can also compare the long term and short term numbers at idle and while running 2500 rpm , numbers equal out close at 2500 rpm is usually a vacuum leak
Old May 18, 2021 | 12:30 PM
Fly skids up!
That's a good question. I think it's got more to do with the ECM then the scanner. My Accutron scanner would read BLM with the stock CFI ECM but won't with the 1614299 ECM I swap it for.
Old May 18, 2021 | 12:34 PM
Mrvettenick
I would stick with Snap on, I've had a few of their scanners, and there's a lot of hardware available even on ebay.
Any of the Snap on scanners are backward compatible, so if you know someone who has one. or someone who's selling one, you don't have to be picky. Just make sure that it has the correct cable and connector, and you're good to go.
Old May 18, 2021 | 07:26 PM
Buccaneer's Avatar
Buccaneer
I guess I should have clarified my earlier post a bit, my bad. I meant, which scanner that "doesn't cost an arm or a leg". Snap-On is way too high to just troubleshoot this issue IMO. There are simpler and cheaper ways to do this without spending your kids college money on a scanner. I think that a simple look at the injector flow/spray will tell you a lot. If it's dripping while spraying or dribbling after turning off the motor, the small o-ring in the bottom of the pod is bad or injector isn't spraying properly, dirty...again, you will be able to see that with a simple timing light. It may have ECM injector driver issues? I don't need that equipment since I'm using the EBL and it tells me a lot of what's going on with the motor/ECM, but a stock motor won't have that benefit unless they use a HAM board with the EBL Flash II.
Old May 18, 2021 | 07:38 PM
Mrvettenick
Define arm and a leg. Anyone who wants to perform diagnostics needs to have one. In this situation the mT2500 can be had for a reasonable price. The OP is complaining of a misfire, Is it fuel or ignition related? Outside of a drippy injector, that's all you have to go on. Everyone has their own approach. .
Old May 18, 2021 | 10:37 PM
Buccaneer's Avatar
Buccaneer
The GM service manual works WONDERS. I suggest that the OP purchase one, it's worth its weight in gold. All you really need is a manual, meter and know how to use both. In my 30 years specifically owning and working with CFI of corvette, camaro, firebird and trans am I have never had to have anything more than a meter and a diagram to find an issue, but that's just me. But I do have other equipment if needed.
Old May 19, 2021 | 01:00 PM
Eric P's Avatar
Eric P
I bought my Snap On MT2500 aka Brick from ebay for 250.00 and it has all the cartidges and connectors plus had all the Ford and Chrysler too , the Pro Link was around 500.00 and GM Tech 1 was 550.00 but I bought a real nice one .
Old May 21, 2021 | 03:50 PM
L-46man's Avatar
L-46man
Default clever ****
Buccy you clever shizzle! never thought of a timing light on the injector nozzles! Unkahal
Old May 21, 2021 | 08:16 PM
Buccaneer's Avatar
Buccaneer
Well, shizzle my nizzle.
To 1982 corvette fuel injector help
