AC Compressor Pulley Rim Came Off
Old May 20, 2021 | 07:47 PM
Mikey1339's Avatar
Mikey1339
Default AC Compressor Pulley Rim Came Off
Driving today when I heard a loud tapping. The entire AC compressor pulley rim came off/loose and was banging against the body of the compressor with every rotation. Can I just remove some screws and put the rim back or is it likely there were some bearings/inertial rings that grenaded the whole clutch? Has this happened to anyone else?
Also how do I remove the AC compressor belt? I guess I have no choice but get a special tool to remove power steering pulley/belt first?
Old May 20, 2021 | 08:38 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
If it were me, I would be replacing that compressor. Also, Special tool to remove power steering belt??? I've had the power steering belt on and off of my 77 more times than I can remember, lossen front and rear lower mount bolts. loosen up upper rear adjusting bolt. swing pump towards block. remove belt. a ratchet, a socket and a 9/16ths combination wrench. nothing at all Special.
Old May 20, 2021 | 10:06 PM
Sayfoo's Avatar
Sayfoo
Does the pulley/clutch have a big bolt in the middle holding it all together?
Old May 21, 2021 | 07:32 AM
Mikey1339's Avatar
Mikey1339
Oh ok cool. For some reason I was thinking the power steering belt required you to remove the pulley and that the PS pump didn't pivot...
Pulley/Clutch assembly seems to have one central bolt and press fitted parts, but the pulley rim seems to be a separate piece that just has little hex head bolts that hold it to the rest of the clutch assembly like it is a "metal skin".
I don't know how to tighten the pulley rim screws. The screws seem to have metal tamper guards that have to be folded aside (like the smog pump bolts with the metal strips). I can't seem to figure out out to fold the tamper guards away other than like smashing them with a flathead screw driver and hammer .
Interestingly with the pulley rim being loose I can slide it back to its normal position and then the whole pulley clutch spins freeley (no binding) and is unlocked as it should be (car off, ac off). I was really expecting the clutch to be stuck engaged... maybe if I put the pulley rim back in place everything will just work?
Old May 21, 2021 | 12:07 PM
Sayfoo's Avatar
Sayfoo
Also, you may be able to buy just the clutch/pulley part. Replacing the whole compressor is kind of a major thing with having to have the system recharged, etc.
Old May 21, 2021 | 01:45 PM
interpon's Avatar
interpon
especially if r-12 is in it..
Old May 21, 2021 | 02:00 PM
Mikey1339's Avatar
Mikey1339
PO said it had been converted over to R-134A (I don't believe PO on most stuff)... I have no idea really. Looking at how original the car is (not in a good way)... It may be R12. How would I know?
Update:
I figure out how to release tabs/bolts to pulley rim (flathead screw driver 90* down, rubber mallet, then 11 mm box wrench on bolts). I am 90% confident these just came loose and let the pulley rim come ajar (bonking bolt on compressor to make god awful sounds). If it stops raining then maybe I can confirm everything still works . I think it was all because I had the cable too tight (recently put AC brackets/spacers back together properly as PO had a few spacers in the "forgotten parts" pile.
Old May 21, 2021 | 03:18 PM
interpon's Avatar
interpon
Update:
you don't... hoping your fix works!! if it worked good before than another good reason to try an fix clutch and not open..
supposed to change fittings and label if converted... but you don't know if they didnt
To AC Compressor Pulley Rim Came Off
