AC Problem Diagnosis Help - Not Blowing Cold Air
Old May 25, 2021 | 05:22 PM
Radovette's Avatar
Radovette
Curious...why the castellated nut directly above the low pressure valve? All my research suggests replacing both the drier and orifice tube when converting to r134a. Also the old o-rings are not compatible with the r134a compressor oil. Replace them. Some say the size of the r134a molecules will creep through the hoses so new hoses have a barrier to prevent that. All in all I replaced everything except the evaporator. It did get a washing out with MEK to remove as much of the old oil as I could while I rebuilt the heater box. Overall a big job. Just changing the ports is only the beginning. Lonnie
Old May 25, 2021 | 05:35 PM
interpon's Avatar
interpon
Pic?
Old May 25, 2021 | 06:29 PM
Mrvettenick's Avatar
Mrvettenick
I wouldn't be concerned about new hoses. Over time the inside of the hoses develop a coating because the oil penetrates the rubber. O rings... yes.
Not sure why everyone is concerned about that clutch. It seems to be working, I'd be more concerned with what's going on inside charge wise, and why it isn't cycling. If you had gauges, you would see what the low side is at, If it pulls down to 28-32, then it should cycle. If the previous guy hot wired that switch. then I would rule him out from any further repairs. Finally, I would NOT run the system at all until the proper charge is in the system. The gas carries oil throughout the system, and you could damage the compressor, if it hasn't been damaged already.
Old May 25, 2021 | 06:49 PM
interpon's Avatar
interpon
clutch..
because of the 19 second mark in the second video you can clearly see the clutch starting to slip and or rotation change from fast slow to fast again...and it would be good to know if working properly or not...
of course gauges are first..noone disputes that
Old May 25, 2021 | 07:07 PM
Mrvettenick
If that was being run under charged for a while, the clutch windings could be over heated from cycling too quickly. I still think it's more important to address the cycling issue. Either way, it's not happy/.
Old May 25, 2021 | 07:09 PM
interpon's Avatar
interpon
the pressure switch is bypassed
Old May 25, 2021 | 07:33 PM
Mrvettenick
Was that done after it was "repaired" in order to address the issue?
Old May 25, 2021 | 10:45 PM
carriljc's Avatar
carriljc
I've done several R-134a conversions and I installed, evacuated, and charged my Hot Road a/c system myself.
On the conversions I've done it both ways: 1) the long way with major components replaced, o-rings, orifice vlv, and/or control valve, dessicant/dryer, etc......and I've also done the quick easy where all I did was swap fittings, evacuate (was pretty much empty already) and recharged. Every one of them has worked and cooled to 40 degrees.
BUT you really need to start by finding out what is going on with your system. Personally I think it is well worth having the a/c gauges and a vacuum pump. The vacuum pump comes in especially handy on troubleshooting the vacuum systems on a C3 corvette too.
You really need to get some gauges and get some readings. We could even tell what the compressor with those gauges. The we can all be more helpful in assisting you in troubleshooting.
Old May 27, 2021 | 09:36 PM
Sdh91's Avatar
Sdh91
Really appreciate everyone’s input. Going to take it to a reputable AC shop this weekend. I will report back what exactly needs to be done to get it working properly.
Thanks!
Old May 29, 2021 | 05:08 PM
Sdh91's Avatar
Sdh91
Update: Took the Vette to an AC Repair shop in Clearwater, FL that has been in business for over 30 years. Solid online reviews. Spoke with them last week and explained what had been done previously. They assured me that they have extensive experience converting systems from r12 to r134a and they doa lot of work on classic cars. I was told that the compressor was bad. They replaced with a new compressor, orifice and o rings. They called me to tell me it was ready and I asked how cold it was blowing. Guy said in the 50s. The thermostat I brought with me and plugged into vent never read below 80 during my 15 minute drive home. I then parked the car in the garage and ran the ac for another 10 minutes. Temp stayed the same. Very frustrated and I called and left a message for the owner to call me.
At this point I’m ready to have them take out the Freon and I’ll bolt on a new condenser and evap myself.
Old May 29, 2021 | 05:11 PM
interpon's Avatar
interpon
if you are not diy then pay by credit card and hold charges til fixed..and if new accumulator is not included and you don’t see new one do not go back...hacks...i would
rather change 10 compressor than that accumulator
Old May 29, 2021 | 05:50 PM
Mrvettenick
As a guide with 134, you should see about 30 deg F below ambient. Is the compressor cycling? The lines going into and out of the evaporator should be cool, and feel about the same.
Don't guess for them, They should ne able to diagnose it.
Old May 29, 2021 | 09:04 PM
  #33
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Can you use the same compressor for R12 and 134?
Old May 29, 2021 | 09:32 PM
  #34
Mrvettenick
Yes. Just make sure all of the mineral oil is out and replaced with the correct viscosity PAG oil. And the O rings should be replaced. Some recommend a new accumulator and a cycling switch for 134 is used.
Old May 29, 2021 | 09:39 PM
  #35
interpon's Avatar
interpon
You will never get the oil out of accumulator nor can you flush it...replace it
Old May 30, 2021 | 10:03 AM
  #36
Sdh91's Avatar
Sdh91
Thanks for the comments. So here is a quick update and a few short videos and a photo:
  • Both lines going in/out of evap are cool to the touch and feel the same
  • The compressor cycled initially for about the first 3 minutes then seemed to not cycle after that.
  • Belt seems loose to me
  • Lots of condensation having only run the ac for about 7 minutes total
Old May 30, 2021 | 10:41 AM
  #37
carriljc's Avatar
carriljc
That is some crappy work if they left the belt that loose. Hard to believe they have 30 years of experience. Take it back and tell them to fix it, to make it blow cold, or to give you your money back.
If that's as good as their service gets then you might be better off doing it yourself.
To AC Problem Diagnosis Help - Not Blowing Cold Air
Old May 30, 2021 | 05:03 PM
  #38
interpon's Avatar
interpon
Tighten belt..
put thermometer in center vent..fan on low doors open..compressor should cycle when vent temperature cycles of anywhere between 34-42f...fat city...
the compressor should not cycle if hot and fan high...
Assumes heater shut off is working
condensation is good
Old May 30, 2021 | 05:29 PM
  #39
interpon's Avatar
interpon
You are also missing hose protector..so that slappy belt does not take out radiator hose
Old May 31, 2021 | 10:53 AM
  #40
Sdh91's Avatar
Sdh91
UPDATE: Thanks again for everyone's comments on this. When first turned on, the compressor clutch engages and disengages about every 10 seconds and then engages less frequently for the next 4 minutes until it does not engage anymore.When it is first turned on and engaging frequently, the system cools to about 61 degrees (outside temp is about 85).
