C3 part name needed please!!!!
Old May 23, 2021 | 09:01 PM
Carlos Salinas's Avatar
Carlos Salinas
3rd Gear
Default C3 part name needed please!!!!
This is my 1977 corvette and I need help figuring out what the name of this vacuum type canister is. Please and thank you.
The cable inside the rubber piece is broken and I’m not sure what’s it’s called
Old May 23, 2021 | 09:21 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
It's called an actuator, but I'm not sure why it's down below the master cylinder and by the steering box. This looks like the smaller diameter (~5"-6") actuator that earlier years used for the windshield wiper door. Maybe '77s had another use for it. There should be two, large diameter actuators (~8"-9") between the headlight doors.
Old May 23, 2021 | 09:30 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking cruise control actuator
Old May 23, 2021 | 10:11 PM
Catfish4818's Avatar
Catfish4818
Yes, it's for your cruise control. Group 3.885, part number 6494922 (may have been superceded by a newer number), GM name is 'servo'.
Old May 23, 2021 | 10:14 PM
bmotojoe's Avatar
bmotojoe
Cruise Control Servo.
Servo & Cable are 77 one year only parts.
Old May 23, 2021 | 10:18 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
If the ball chain just broke, it is an easy fix. I just bought a drain plug at Home Depot that had that style chain.
Old May 23, 2021 | 10:28 PM
bmotojoe's Avatar
bmotojoe
Yep, correct group and part number.
The Cable is Gr. 3.880 GM #460824.
Both are VERY hard to find new or good used.
Old May 23, 2021 | 10:32 PM
bmotojoe's Avatar
bmotojoe
Yes I believe it is a #10 chain or 4.5mm
Old May 23, 2021 | 10:46 PM
bmotojoe's Avatar
bmotojoe
This is how to vacuum test the Servo:
Old May 24, 2021 | 09:59 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
cruise controller actuator and its name is Steve.
To C3 part name needed please!!!!
