Anyone re-wired their C3??
Old Dec 15, 2002 | 07:31 PM
Corey_68's Avatar
Corey_68
Default Anyone re-wired their C3??
I ordered a Painless Wiring 12 circut harness. I'm using Autometer gauges throughout the car. My only concern is the wires and headlights since they are both vacuum actuated. and have to use the existing harness for them.
Anyone done this before?? :confused:
Old Dec 15, 2002 | 07:43 PM
lason's Avatar
lason
Default Re: Anyone re-wired their C3?? (Corey 68)
havent done this yet but I was planning on doing this in the future. I was planning on running the #20102. Its says it mounts through the firewall on a couple '60's GM's so it looks like it will work nicely.
Old Dec 15, 2002 | 07:52 PM
groovyjay's Avatar
groovyjay
I have done all my wiring from scratch, plus I just ordered a electric head light convesion. Which Autometers are you using? :cheers:
Old Dec 15, 2002 | 07:56 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Anyone re-wired their C3?? (groovyjay)
groovy, where did you order that? From 69myway? if so, are you sending your headlamp assemblies or is he now selling DIY kits???
Marck
Old Dec 15, 2002 | 08:02 PM
TPIShark's Avatar
TPIShark
The vacuum hose routing and the physical wiring for the headlamps are completely separate items. The only thing they realyl share is the actual headlamp switch in the dash, which is a combination electrical switch and valve. I was able to take my wiring harnesses (they are several sections, for example the bulkhead connector at the firewall sperates the forward lamp harness from the engine portion) and carefully clean, inspect and repair/replace connectors, followed by a complete re-wrap in that harness tape that Eastwood has. (no glue, almost like wrapping handlebars on a bike) However, if you see serious cracking of insulation or coroded wires, I would consider replacing sections or the entire setup with correct replacements. Universal types are great for customs and street rods, but will only give you increased headache in a 'Vette, just my .02. If your harness has been "modified" by various individuals over the years, I would also replace it. Even though mine was salvagable, I sometimes regret not replacing because I know I'll have to do it someday anyway.
:flag
Old Dec 15, 2002 | 08:06 PM
Corey_68's Avatar
Corey_68
How much was this and what all is involved in the conversion?
I went with the Autometer pro-comps.
:cheers:
Old Dec 16, 2002 | 01:03 PM
Corey_68's Avatar
Corey_68
Any ideas? :confused:
Old Dec 16, 2002 | 01:32 PM
mrvette's Avatar
mrvette
Corey, on my '72 there, the engine/main power harness is in the inboard section of the two piece bulkhead block, the lighting is on the outboard section....that simplifies stuff a whole lot....
the under dash wiring is another matter, and involves much duplication due to GM's hurried/harried designs....the routing is amazingly silly, much can be eliminated....but it takes time and electrical know how....I found the worst of the project was sitting on boards and buckets inside the car leaning over working on the wires....but over several months, I got it done.....last winter...
glad to help with specific questions...
mrvette72@interstateweb.net
GENE
Old Dec 16, 2002 | 03:54 PM
groovyjay's Avatar
groovyjay
Are you talking about the re wiring or the head light conversion. I haven't looked into the the old bills yet, but will do that after the project is finished, but I think by doing the electrics from scratch I saved few bucks, plus I got to do lot of custom stuff, like I mounted the fuse box and all relays in the storage box behing passenger seat. I also modernised the system a bit. However if you ment the headlights, you should take a look at here:
http://www.corvetteactioncenter.com/...threadid=18214
Like Twin Turbo guessed it's the 69MyWay's kit and it uses C4 motors with custom made brackets. The kit goes for 695$.
To Anyone re-wired their C3??
