Caliper bleeder locations
Old May 25, 2021 | 11:43 PM
Mpls Funk's Avatar
Mpls Funk
Default Caliper bleeder locations
I made the rookie mistake of not taking pictures before I tore my calipers apart for rebuilding. I purchased a set of new bleeders and it came with 6. It appears the fronts only get one each, so that would mean the rears each get 2? But the rear calipers have 3 holes thst would fit a bleeder and one thst is for the brake line. Which holes in the rear get a bleeder? I assume the left over hole gets a plug?
Old May 25, 2021 | 11:52 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
When the caliper is mounted, the top inboard and outboard get the bleeder screws. The lower inboard is the line fitting; the lower outboard gets a solid plug.
Old May 25, 2021 | 11:53 PM
Mpls Funk's Avatar
Mpls Funk
Perfect... Thank you!
To Caliper bleeder locations
