AC help needed
Old May 29, 2021 | 01:53 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Default AC help needed
Hello
New C3 owner long time Vette owner here, and I will be asking alot of questions as I go thru repairing and replacing stuff on my new to me 72 coupe.
It is an excellent 1 owner 120K mile car that has been well cared for and sat in an AConditioned garage in Calif for the past 50 or so years.
Pretty much in the same condition as it left the factory. I dont want to be the one to screw it up, but I plan on some stuff that will hopefully
improve what GM designed.
My current problem is the AC compressor keeps cycling off and on and I need to fix it here in Phoenix in the summer time. I'm thinking a bad clutch
but wonder what else could it be? Any at home tests I might try?
TIA
Dan
Old May 29, 2021 | 02:11 PM
derekderek's Avatar
derekderek
generally that is low refrigerant. runs until the suction-lpw pressure-side pressure drops too low then shuts off. soon as it shuts off the pressure rises until it says it is good and fires up again. is it still r12? or r134. get this.
Amazon Amazon
Old May 29, 2021 | 02:28 PM
derekderek's Avatar
derekderek
or a cheapo real gauge set. which also works for r 12.
Amazon Amazon
the system is charged to around 40 to 70 psi or so when not running. when compressor starts, low side drops to about 25-40 psi. if it drops too low compressor shuts off. them pressure rises and low pressure safety disengages and it starts again. now, a blockage can cause high pressure limit switch to also make system cycle. but low level more likely. a slight leak can be pricey to find and repair. if a weekend car, it may be more cost effective to add enough refrigerant to make the system happy for the day or few hours as opposed to paying hundreds and finding the leak is still there...
Old May 29, 2021 | 03:14 PM
0311 jarhead
or a cheapo real gauge set. which also works for r 12. https://www.amazon.com/R134a-Manifol...a-779844550016 the system is charged to around 40 to 70 psi or so when not running. when compressor starts, low side drops to about 25-40 psi. if it drops too low compressor shuts off. them pressure rises and low pressure safety disengages and it starts again. now, a blockage can cause high pressure limit switch to also make system cycle. but low level more likely. a slight leak can be pricey to find and repair. if a weekend car, it may be more cost effective to add enough refrigerant to make the system happy for the day or few hours as opposed to paying hundreds and finding the leak is still there...
Thank for the info. I think its still R12. I have all the maint records and it was always taken to Gulstrand for repairs since 1973. I will try and find someone who still has R12 and
Try that first.
Old May 29, 2021 | 06:36 PM
kansas123's Avatar
kansas123
I was not aware that the '72 would cycle on and off. Hmmmm I thought if it got too low on freon and caused the compressor distress, that the thermolimiter switch would melt to save the compressor....
Old May 29, 2021 | 06:43 PM
0311 jarhead
I just drove across the desert from LA to Phoenix and it was going off and on the whole way. Completly stock AC system
Old May 29, 2021 | 07:25 PM
interpon's Avatar
interpon
I would get some gauges..first step for anything..
doubtful though you can loan r12...rare...
you are too far for me to loan
might be good to take a pic of fittings...just to be sure r12 fittings...
Old May 29, 2021 | 07:29 PM
stingr69's Avatar
stingr69
They click on and off on low charge. After all those years the seals are shot. R12 leaked out.
I am resealing mine now. Bought the green O-ring kit from Zip and the compressor seals/tools from Century Auto Air. Guage set from Toolsource. We have a case of R12 that I aquired years ago. Almost ready. Need a new accumuator dryer and vacuum pump then just get after it.
Old May 30, 2021 | 08:37 AM
VERYSOON's Avatar
VERYSOON
Hey Stinger69
If you have a stock 69 system I would put in a new expansion valve, too. They are cheap. Got my accumulator and valve from Old Air.
VS
Old May 30, 2021 | 08:49 AM
stingr69's Avatar
stingr69
I have a stock '80 system. My plan is to keep it original as possible but fully functional. I know the history so that helps. No component failures that I know about. If it holds vacuum, it should work.
Old May 30, 2021 | 09:40 AM
0311 jarhead
Thanks. I plan to keep mine as orig as I can too, within reason. I know the history too and the major parts were replaced about 10-15 yrs ago.
So just some juice might be all I need. I'll try that and some dye first.
Old May 30, 2021 | 12:17 PM
stingr69's Avatar
stingr69
If you can afford the 3 lbs of R12 just to test it? You do know you have a slow leak somewhere right now. If it leaks out fast after you fill it you are still doing a re-seal, evacuate and recharge later. Judgement call there.
The new green o-rings are pretty darn cheap and so is a compressor overhaul. The currently available replacement compressors are kind of suspect these days. I know my o-ring seals are 40 years old so a basic system overhaul is cheap insurance here. If R12 gets crazy expensive in the future the system will already have 134a compatible seals. I plan to stick with mineral oil for now. Flush it out if or when it's time to convert. That is the plan so far.
Old May 30, 2021 | 12:43 PM
0311 jarhead
Wheres a good place to get R12? A friend is giving me some, but I need to find more. Ebay seems like a rip off
Old May 30, 2021 | 12:55 PM
Lestat52's Avatar
Lestat52
I believe you need a certificate or license to buy R12. Possibly a shop can fill it for you. Any R12 I have seen fir sale required it and was $$$$$$$
Old May 30, 2021 | 01:06 PM
stingr69's Avatar
stingr69
I used to be in the HVAC business years ago. We had techs with certification so it was not hard to get at that time. I have retired from that business so I would not know where to find any more. If you find some, use it sparingly.
Old May 30, 2021 | 04:45 PM
boat196's Avatar
boat196
Craigslist is a good possibility, I purchased a 30 lb container of R12 off of Craigslist.
Bob
Old May 30, 2021 | 04:56 PM
interpon's Avatar
interpon
Please do not open system yet..
you need gauges first..
are you sure its r12? Did it work before? Gauges and a small investment may last a year..it may last a day...no foul yet...
lets go with what we know first..
r-12 ebay and craigslist is where i get mine..but lets be sure you know what you have first...pics of fittings ?
Old May 30, 2021 | 06:54 PM
derekderek's Avatar
derekderek
R 12 fittings look like tire valves. R 134 fittings look like air hose quick disconnects. snap a pic of your fittings but this should answer. if 134, a 20 buck charging hose with gauge in it will do the trick. snap it on. see what pressure is. start car and run ac. you will see the pressure drop when compressor fires and climb when it shuts off. post all 3 readings. if r12, get the 29 buck gauge set. you can't get r 12 but you can go to an HVAC guy sounding like you know what you need, and a screwin is not part of it...
To AC help needed
