I have a numbers matching L79 HT code engine. It has a Holley 4175 that works well, I don't really want to change it. 60,000 miles,,,,,,I think. I would like to get it refreshed/overhauled. I don't want different exhaust manifolds, heads, intake ETC. A bit more power wouldn't hurt. It's supposed to have 11:1 compression and 350 hp already. I know the old engines have issues with the unleaded fuels today that could be upgraded. What needs to be done to the engine and what would be good to do? Just for the engine. I know there are millions of thing I can do to other systems while it is out. Could this be done and not remove the entire engine from the car? About how much should it cost?
First you need to tear it down and measure the bore see what kind of wear/taper it has.
That will dictate if you can ring/hone which Im not convinced lasts long or rebore.
Probably doesnt have an honest 11-1. Id so a nice valve job, portwork and a roller cam for power increase you can actually feel. It will still appear stock outside 100%
Mark ie Vortecpro is out by you, he is expert with builds like this and iron heads
PS easier to pull the whole engine doenst take long and makes it so much easier to work on. You should be putting freeze plugs and more, cant do it in the car
New pistons, valves and seats, push rods, main bearings? A new cam is only $230 ish. I wouldn't mind looking at different cams to go with the build, but nothing to radical.
I dont think youre gonna get all that for $230, good roller tappets cost that much. Pull the heads, check the bore, if its good get some good alum heads (trick flow. AFR) intake and a matching Carb. Best bang for the buck.
You can easily do that at home and you dont have to pull the motor. 60K miles is nothing if it was taken care of. Mine has exactly twice as yours 120K and it runs like a swiss watch. I'm just gonna pull it clean it up and put it aside for the next owner. No reason to open a perfectly good #'s matching motor.
I have the same L79 in my 68. I used new 11:1 pistons, Comb roller cam, roller lifters, comp magnum roller tip rockers, port pocket the original heads, new valves. Reconditioned the rods and crank. I have the original Quadrajet rebuilt. It dyno'd at 383 hp and 423 tq. Plenty of fun for me.
PS. The CR is closer to 10.5:1 with the Felpro head gaskets i used.
I'd be checking your distributor advance and the general operation of it confirm your timing. Make sure your carb opens fully when you push the gas pedal to the floor. The L-79 was a strong running engine I'd make sure everything is fine before you tear into it.
i would leave the bottom end alone if compression is good. that steel crank and forged pistons are very nice pieces-and collector's items. pull the heads and get a good valve job and do some bowl area clean up. this is one of the few where "numbers matching" actually means something.
my 75 L48 is numbers-matching. because no prev owner was willing to spend the money to put a real engine in it. at least they did L82 valve covers!
Pull the valve covers and see if the cam is going flat. A stock replacement cam and a set of heads would probably work well. You might also check your timing chain that's a likely suspect too.
Have you done a compression test or a leak down test. If your short block checks out, you could refresh the heads. That would allow you to leave the motor in the car.
Redoing the heads is a good idea. So if I redo the heads, I wouldn't have to worry about using zinc additive in the oil? How much should this cost? I have done a compression test. I am at 5000 ft so the numbers are very different than sea level.
You can buy aftermarket heads cheaper then doing yours. Check Summit online. Intake, carb and a disto if needed and youre done. Right around a grand ? if you do it yourself.
ZDDP (zinc in the oil) has nothing to do with the heads. It is an additive for flat tappet cams and not required if you go to roller cam.
I see you are in Colorado also, so don't overdo the duration on the cam. High altitude likes less duration on a street car. Just my .02
I am going to keep the carb and distributor, they have been rebuilt. I would like to keep the intake unless it's bad or there is a great upgrade that would fit.
What he said^^^^
Its the gas that eats up old soft iron valve seats
