dash lights
Old May 30, 2021 | 08:18 PM
robertwg's Avatar
robertwg
Default dash lights
All lights are fine except dash lights are dim. Wondering bad ground or light switch. 76 vette
Bob
Old May 30, 2021 | 09:28 PM
kansas123's Avatar
kansas123
What year? my '72's were quite dull/dim, simply because that's the way they were. Til I changed them to super bright LED lites, now bright as a penny. And I have to ask, you turn the headlight switch all the way to the brightest setting?
Old May 30, 2021 | 10:42 PM
Yadkin's Avatar
Yadkin
Since they are on a dimmer, locate that and bypass it with battery voltage. If it improves, then you know the dimmer should be replaced.,
Old May 31, 2021 | 11:32 PM
robertwg's Avatar
robertwg
dimmer is turned all the way up
To dash lights
