Rear axle noise?
Old Jun 3, 2021 | 03:49 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
Default Rear axle noise?
My 72 C3 makes a clunking noise when I'm backing up and feels like something is binding up. I checked the
drive and 1/2 shaft uni joints and nothing seems loose. Any ideas? Rear gears? Posi unit?
I know its not much to go on. Anything else can I check?
Old Jun 3, 2021 | 05:15 PM
GTR1999's Avatar
GTR1999
could be the snubber bushing being worn, many times the pinion seal leaks oil on it. Posi chatter typically shows up when you take a turn and side load a clutch pack. You can try a simple oil change with 2 bottles of posi additive. If the clunk is direct in the diff and consistent then you might want to remove the diff and the cover for inspection.
Old Jun 3, 2021 | 06:10 PM
0311 jarhead
Thanks, I'll check that out
To Rear axle noise?
