Also,for the pins, do you just grind the top off and then tack weld it when reassembling?
again, many many thanks
Right or wrong, I'm not sure, but I did it and it worked. I can't remember if I was able to repair the other planetaries or not, it's been a few years. I'd say if you can get them apart without damaging the carrier or bearings you're golden.
From some research Ive done today the 86 and newer 2004r stock transmissions can handle 300hp stock with no mods. They are supposedly good to 400hp in normal use and if drag racing they are supposedly only good for like 300-350hp... I'm sure this opinion varies but thats what google states.
My belief as well. I'm putting a rebuilt stock 1985 2004r tranny in my 1979 L-82. Not a Hot Rod, just a cruiser.
