Dumb Question!
Dec 16, 2002 | 04:26 PM
Dumb Question!
I know that in 1972 there were no gaskets between the head and exhaust manifold but when reinstalling, does the side of the gasket with the metal face go against the head or the exhaust manifold????
:confused:
Dec 16, 2002 | 04:28 PM
Re: Dumb Question! (l2vette)
:confused:
:confused: :confused: When reinstalling, don't use gaskets. Factory didn't and they were not designed for gaskets.
tom...
Dec 16, 2002 | 04:32 PM
Re: Dumb Question! (Tom73)
There were gaskets on the exhaust manifolds I removed. But I had to replace them...one was cracked! :cry
Dec 16, 2002 | 04:35 PM
I made this mistake too. I thought it wouldn't hurt putting a gasket in there and I was wrong. One got cracked (blew out a section) causing a leak. I hate doing rework..
Dec 16, 2002 | 08:28 PM
Re: Dumb Question! (Koz)
O.K. so I will l will leave out the gaskets, what should I torque the bolts too, is it 20 ft. lbs. ?
Dec 16, 2002 | 11:02 PM
The specs are not clear,are all the bolts at 20 ft. lbs. can anyone help!
Thanks!
:cheers:
Dec 16, 2002 | 11:16 PM
The Service manual for my 73's says it is 20 ft lbs with the exception of the "inside" bolts which should be 30 ft lbs.
tom...
Dec 16, 2002 | 11:21 PM
I guess that's my question, what does that mean "the insde"
Dec 16, 2002 | 11:40 PM
Would assume the two bolts around the center two ports.
tom...
Dec 17, 2002 | 10:57 PM
Does anyone know for sure??
:confused:
Dec 17, 2002 | 11:31 PM
Cruise-In III Veteran
tom...
Good assumption.
I would suggest tightening the inside bolts first to control any wrapage. That's probably why they have the higher torque specs for those.
