I currently have standard brakes that will soon incorporate an O-ring conversion for the calipers. My question is would it be worth it to convert to power brakes "while I am at it"? What all is involved in the conversion? Does it give you better brakes or just reduce pedal effort?
Just my 2 cents: Under normal driving conditions power brakes are probably better because of reduced pedal effort and force required. Under extended periods of hard braking and wide open throttle operation you could "use up" the vacuum stored in the brake booster and not have very good brakes at all, or at least have brakes that are harder to stop with because of increased pedal effort. Therefore, with your standard (non-power) brakes your braking power should be more predictable under racing conditions. But of course under these conditions you would probably want racing rotors to reduce brake fade from heat. :steering:
I have manual brakes like you and would only convert over to the hydro-system since it is about the same $, maybe cheaper if you go junkyardin', as converting to vac assisted power brakes. My brakes work fine so I am not to concerned about it for the time being.
I own both, and while the power is nice, it's not really necessary. I get used to either in a few seconds. Either car can lock up the tires at any speed that I've ever tried it. If I did convert to power brakes, I would go with the Hydroboost unit (Actually, I have the unit, but not the motivation to install it :lol:). Putting a vacuum booster in a manual car is a pain, because the pedal rod height, brake lines, and firewall mounts are all different.
-Joe
[EDIT] FYI, while I don't really have a preference, my wife absolutely loves the power brakes. I guess leg strength plays heavily into this decision.
I drove my vet for about 11 years without power then switched to hydraboost, used parts for about $100 total and find the braking far superior. I would never go back to non-power. I had performance friction bads but found them chewing up my rotors. Now I use wagner organic pads and replace them every year in routine maintanance.
