Requested: Clutch Pedal Measurement
What I am up to is trying to get a lighter clutch pedal. I believe the C3 has a short pedal and a bad leverage ratio. And yet I need a strong clutch for my BBC. I will most likely be going to a dual disc setup to get the pedal pressure down.
When I drove my BB into the garage (for the two blocks that I drove it) the clutch pedal pressure was terrifically high. I want the opposite, as easy of a pedal as I can get.
I also do not need the 1200ftlb capability a dual disc offers me. I only have 550 ftlb. But the single disc versions have a strong pedal.
I am currently collecting data from McLeod and also Ace on their dual disc clutches. Then if the pedal pressure is still not as light as I would like it, I will be talking to H&R locally and have him build me a custom one. The dual disc versions have so much disc area they can get by with much less spring pressure than they currently have. Stay tuned.
Contrary to popular belief, a hydraulic clutch does not change the pedal linkage ratios at all. That is determined by the 6.5" pedal movement and the 0.5" clutch finger movement.
It will have a little less friction, but that's not significant over a properly built/maintained mechanical system. They do not get stiffer over time and need less grease/maintenance over time, that's true, until they leak & suffer complete & catastrophic failure. It does allow for different packaging, but that is kind of irrelevant for our cars since they were designed with a z-bar. So IMHO on our cars it is a mod looking for a problem to solve. So why do it? Just to replace a worn-out stock system? Why not just get the stock system working well?
