Timing light?
Old Jun 20, 2021 | 06:29 PM
eddp's Avatar
eddp
Default Timing light?
This should bring some interesting responses. I have a Matco MTL500 Timing Light. When I have it on zero advance, the light flashes at the timing mark and 14 degrees on the tab. When I advance the light to 14, so the mark should and light should flash at zero on the tab, it jumps back and forth from zero and 14 on the tab? When I back the light to zero again, the mark and light flash at 14 on the tab? Any thoughts?
Old Jun 20, 2021 | 07:54 PM
HeadsU.P.'s Avatar
HeadsU.P.
I have read your post 9 times to make sure I am somewhat confused. The 10th time had me completely confused.
The light displays what your distributor is set at. The light does not display what the dial-back is set at.
Maybe.
And for what its worth, some lights have a hard time picking up signals from HEI systems. That's normal. I have learned to ignore an occasional jump of the blimp.
Somebody will help you soon.
Old Jun 20, 2021 | 08:10 PM
bluthundr's Avatar
bluthundr
Make sure your vacuum advance is disconnected and the vacuum line plugged - a golf tee is the GM approved temporary plug for that line
Old Jun 20, 2021 | 08:52 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Are you using a multi-spark ignition?
Old Jun 20, 2021 | 11:22 PM
derekderek's Avatar
derekderek
get some white out and set Tdc mark at 15 degrees. Paint a mark where 0 is. Now you have a 15 mark. Move that mark to 15. Paint another mark at 0. Now you have a 15 and a 30 to go with the tdc mark. So initial is 14 and you can watch the 2 other marks as advance kicks in.
Old Jun 21, 2021 | 06:56 AM
Harris Roc Malouda's Avatar
Harris Roc Malouda
CD-ignitions confuse adjustable timing lights. Multi spark adds up on that.. could be a reason?
Old Jun 21, 2021 | 07:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
As stated above.....the MSD or other multiple spark boxes are not happy with dial back delay timing lights......
If you do not have an MSD box......then try another dial back light to see if it skips around on the dial back function......
This is why a 0-60 balancer is recommended for performance builds as they would be the most likely to use one.
Jebby
Old Jun 21, 2021 | 07:27 AM
69ttop502's Avatar
69ttop502
If you rev an engine with a multi spark ignition up to 3000 or so, where it is just one spark, a dial back light will work fine to check total advance.
Old Jun 22, 2021 | 03:04 PM
Bergerboy's Avatar
Bergerboy
All of the above, plus:
Double-check that your spark sensing clamp is positioned on the #1 plug wire, and AWAY from all the other plug wires.
I've experienced what you described, if the clamp is leaning too close to another wire, so it's sensing 2 different sparks.
To Timing light?
