Brake shoes, manufacturing error?
Old Jun 22, 2021 | 04:06 AM
jlcatch22's Avatar
jlcatch22
Default Brake shoes, manufacturing error?
Changing the brake shoes on my C3 for first time, and the brake shoes I’ve received from zip-corvette have the hole for the lower spring in a different spot than the original (original spot in blue, see picture). Are some brake shoes made like this or is this an error on zip’s part?
Old Jun 22, 2021 | 08:40 AM
interpon's Avatar
interpon
assume these are for e brakes? what is your year? the only c3 e brakes i see on zip pics don't look like those..
pic of old ones?
Old Jun 22, 2021 | 12:10 PM
jlcatch22's Avatar
jlcatch22
pic of old ones?
mines a 73. These are the ones i ordered
https://www.zip-corvette.com/65-82-p...ess-steel.html
Old Jun 22, 2021 | 12:24 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
It helps members identify problems when you take a picture of the entire part. The pic you posted is a good close-up.
Old Jun 22, 2021 | 01:30 PM
Sayfoo's Avatar
Sayfoo
IF the rest of the shoe is the same as your old one, just drill a hole in the appropriate area.
Old Jun 22, 2021 | 01:36 PM
jlcatch22's Avatar
jlcatch22
It is the same otherwise, I’ll probably just drill a hole as you say
thanks, edited original post
Old Jun 22, 2021 | 01:56 PM
interpon's Avatar
interpon
disappointing.. i see they don't say USA made.. oh well..
i think you are right.. not made right.. drill the stainless or if time permits they will make it right.. i would at least notify them so they know/ correct vendor
Old Jun 22, 2021 | 02:38 PM
bluthundr's Avatar
bluthundr
Your old ones look like they have plenty of material on them, put the old ones back in and send the new ones back to Zip
Old Jun 22, 2021 | 02:55 PM
jlcatch22's Avatar
jlcatch22
both the photos are the new ones
Old Jun 23, 2021 | 10:35 AM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Nope those are bad. Thank you for posting this, I have not seen this issue on them yet. There are a couple of boxes in the last shipment that I have found where that hole is not correct. Please call sales at Zip and we will get this replaced for you. I have the correct ones on the shelf.
Thank You and sorry about this.
Also as a note, there are no companies in the U.S. that produce park brake shoes for the Corvette anymore.
Old Jun 23, 2021 | 07:16 PM
BKarol's Avatar
BKarol
Nice to see a company, once advised of a problem, react quickly with a fix. Kudos to ZIP on this one.
Old Jun 23, 2021 | 08:06 PM
jlcatch22's Avatar
jlcatch22
Thanks for reaching out
I contacted zip today and they are sending the correct ones
To Brake shoes, manufacturing error?
