Hooker sidepipes, trim rocker panel??????
Old Dec 17, 2002 | 12:14 PM
Smitty's75's Avatar
Smitty's75
Default Hooker sidepipes, trim rocker panel??????
Did you haved to do anything to the rocker panels to install the sidepipes, the guy who installed mine cut notches in them to put the bolts in the frame???
Old Dec 17, 2002 | 12:19 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Hooker sidepipes, trim rocker panel?????? (Smitty's75)
Yes mine required a bit of trimming to get the rocker panels to fit with the sidepipes :)
Old Dec 17, 2002 | 01:58 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Hooker sidepipes, trim rocker panel?????? (SmokedTires)
Smitty- luckily mine required no mods, but I have seen some that required trimming up at the front, I guess it all depends on what year C3 it is. On my sidepipes I bent the tabs down so they were straight and mounted them to the underside of the frame rather than notch out the rocker panels.
Old Dec 17, 2002 | 02:30 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I had to trim mine.... Took 5 minutes with a cutoff wheel :D
Old Dec 18, 2002 | 06:54 AM
Arkansas Flash's Avatar
Arkansas Flash
I have had them on two 78 Pace Cars and had to trim the passenger side only on both. One car required only slight trimming, the one I have now required a lot more. I guess it's due to production variations in both the cars and the headers.
To Hooker sidepipes, trim rocker panel??????
