Driver's side lean
Old Jul 5, 2021 | 10:47 AM
L-82 4Speed's Avatar
L-82 4Speed
Default Driver's side lean
My 79 sits one inch lower on the drivers side than on the passengers side when measuring from the center of the wheel opening to the floor. I measured from the frame to the floor and the drivers side is 3/4" lower at the frame front and back. At first I thought maybe the body mounts were causing it but since the frame is lower on one side I'm guessing it has to be something in the suspension. Any ideas what could be causing this?
Old Jul 5, 2021 | 12:27 PM
interpon's Avatar
interpon
my same car is now pretty close but still 1/2 inch lower on drivers rear..it got better after alignment (4 wheel)…try it otherwise seems many are..
Have not measured this but what do you get
Old Jul 5, 2021 | 01:42 PM
L-82 4Speed
My measurements from the center of the wheel opening to the floor are:
Right Rear-29&1/8"
Left Rear-28"
Right Front-29"
Left Front-28"
Old Jul 5, 2021 | 01:44 PM
sunflower 1972's Avatar
sunflower 1972
Trust me, yours is NOT the only one! https://www.google.com/search?q=one+...client=gws-wiz
Old Jul 5, 2021 | 02:07 PM
interpon's Avatar
interpon
Right Rear-29&1/8" me 28 1/2
Left Rear-28". 28
Right Front-29" 28 1/2
Left Front-28"
. 28 3/8
today that is..tires 26 front 28 rear
it was much more varied and different priorto 4 wheel alignment
To Driver's side lean
