Window won't roll up fully
Any suggestions?
https://www.youtube.com/watch?v=iM3RNvD6f40
If doesn’t go up all the way with door open it is an easier adjustment. Loosen the front and rear stop screws, move the window up until it seats in the weatherstrip, and tighten back up. Your AIM will diagram the exact screw location at the top of the window track. If this compromises the front or rear gap you will to readjust there as well. I noticed the guy in the video still had a gap after 30min of adjusting, and he never did show exactly what he did.
If adjusting the up stops throws other things off, you might have to do multiple rounds of adjustments all around. Or, put window handling suction cups on the glass with all the screws loose, then tighten them up after getting the glass in position with the door closed.
The new outside window felt was so difficult to adjust for, I left the old one in on the other side.
B is the up stop. D&E for inboard/outboard
It seems there is a slight difference in the metal that holds the felt. More precisely, the angle and size of the "tab" that fits in the hole of the door.
I hope you kept your old original GM units for comparison. Look real close. The after-market is different.
Laying the new & old side-by-side, you can take a Dremel Tool with a cone shape stone and modify for correct fitment.
I had the inner door panel off. What should have been a 30 second job turned into a 30 minute job.
Go to the local landfill and start ripping open garbage bags the same color as yours.
How many could there possibly be, right?
Plan "B".
Compare the new felts to the passenger side door felts. That would require inner door panel removal though.
For what its worth, my drivers side new felt is still not right. The felt allows the glass to strike the weather stripping harshly. Needs tweaking again.
Usually final adjustment can be done with a really small box-end wrench when the window is down.
But in your case, some grinding on the felt bracket is needed.
