My heater has been on the fritz for a while, and it's getting cold now. I just installed a new valve, but a vac hose seems to be missing from the system. Where's it go, what's it do?
Hose corresponds with the hole by my thumb.
Thanks in advance!
-Steve
[Modified by Pacin'California, 12:23 PM 12/18/2002]
The vac. line from engine gets damaged from heat - a small plastic tube that goes in below the hood theft switch into wiper valley. Replacing most of engine side w/ hose will fix.
The hose to heater valve (in heater hose) underhood probably also needs replacing.
