Baer remaster master cylinder (help needed)
Old Jul 31, 2021 | 09:40 AM
jarrettslee's Avatar
jarrettslee
Default Baer remaster master cylinder (help needed)
I have installed a Baer remaster to my 1973 corvette and I have not been able to get it to work properly. I know the brake lines are different sizes 3/8 and 1/4 on the stock master cylinder & the remaster has two 3/8 lines exiting our. So I replaced the rear 1/4 brake line going from the MC to the promotion valve(pv) with a 3/8 lines with new PV fitting. I am confident all air is out of the system and the rear brakes will not engage which is making the brake pedal go to the floor. My next step is taking to baer and replacing their reMC second step going back to my stock set up. I also thought about having a bad PV but if it was bad wouldn’t the rear brakes only engage and not the front? If any one has installed a remaster on their C3 I would love to hear from them. I have a 1973 350sb with power brakes and a brake booster.
https://baer.com/Remaster.html
Old Jul 31, 2021 | 02:13 PM
Sayfoo's Avatar
Sayfoo
Check that the rod from the booster is the correct length. There are adjustable rods available or you could make one from a piece of bar stock.
You should only have a very small gap (1/32"+) between the end of the rod and the mc piston.
Old Jul 31, 2021 | 02:19 PM
jarrettslee
Hi thank you for the reply.
I have a special tool I purchased to measure the length. I don’t think that’s the problem.😟
https://baer.com/Push-Rod-Length-guage-6801279.html
Old Jul 31, 2021 | 07:45 PM
kodpkd's Avatar
kodpkd
Is your PV original? What one do you have? Is the rest of your brake system original C3?
Old Jul 31, 2021 | 07:47 PM
jarrettslee
Yes it’s original along with the lines. But the lines are good and I have baer fron5 and rear brake calipers.
Old Jul 31, 2021 | 07:48 PM
Sayfoo's Avatar
Sayfoo
Yea, that"s the tool. They got you a bit at $49.
Anyway, why did you change the master cylinder?
What problems were you having?
Does the new mc have the correct bore size for a pb car?
When my booster went bad, the brake pedal was very hard, but the brakes barely worked.
Old Jul 31, 2021 | 07:49 PM
jarrettslee
The MC was leaking so but no other problems except replacing fluid.
Old Jul 31, 2021 | 07:50 PM
jarrettslee
The new MC has 1” bore.
Old Jul 31, 2021 | 08:53 PM
Sayfoo's Avatar
Sayfoo
I believe that the oem for pb was 1 1/8".
Old Jul 31, 2021 | 08:58 PM
jarrettslee
Baer only offers the one inch and wants you to extend the Booster plunger thing. Bottom line: I think my MC is a no good. I’m going to send it back. Thank you the help. I’ll update you when I get the new MC.
To Baer remaster master cylinder (help needed)
