68 trailing arm bushings
Without taking half your rear end apart. How does it handle? Like a sports car? or twitchy? wondering when going down a rutted road?
I’ll replace the shocks and leaf spring bushings but might leave the strut and trailing arms bushings to a professional. From what I’ve read those can be a real problem and require tools I don’t have.
Any idea what it might cost to have a shop do the strut and trailing arm bushings?
To go through that and just replace the bushings on a 50 year old set of arms makes no sense as the parking brakes are probably seized, the bearings dried out, and who know where the rotor runout is.
I’m pretty handy, but thinking this might be a job for an expert. Finding an expert I trust with the car is a problem.
https://www.corvetteforum.com/forums...bolts-out.html
Sawzall and good blade are required to cut through the bolt holding them in. Some people were able to actually get the nuts to break free and avoid cutting. They are what we call the minority.
My guess would be if the shims are rusty the bushings were never replaced at least in the last 30 years. Almost anyone would have used stainless shims since them. You can certainly pull the TA's yourself with some labor - once I accepted my fate and gave up on the nuts coming off, then accepted my fate and decided to buy the right tool, then accepted my fate and bought the right blade I had them out in 15 minutes. I probably had 4 or 5 hours in before that.
What does that entail? I assume the TA gets detached from the wheel hub before sending out, or is that part of the rebuild?
I have more time into prep work then some places take to build the whole job but there's a huge difference. Many guys have done this at home, some better then others but they all know what they got when they were done, not something you can say about every job you send out. Last bit of advice, don't get caught up on price alone. Some jobs are low balled to get your work, then you get a completely revised bill later. Also, the advertised prices you find online, in a catalog, on ebay, etc they usually only cover the common parts. Until the arms are inspected by an honest, knowledgeable, experienced person you won't get a real quote. Kind of like some guys I walk through a build and they now know more from doing one than what I experienced working on vettes since 1978.
You will need some tools, a lot of patience, but if you want to do it you can.
63-82 Rear Trailing Arm Rebuilding | Corvette Forum : DigitalCorvettes.com Corvette Forums
Do you do this job for others? If not, would you suggest Van Steel for the work?
A primary item was that if you plan to keep the rotors that are on it be sure the guys doing it know the difference between allowed thickness for minimum after refinishing vs replacement end. By the book, if the rotor is being refinished it can be taken down to 1.230". Replacement is required at 1.215". Some people who do this work seem not to know the difference and assume as long as the refinish leaves more than replacement it's OK. It's not. Any refinish that takes it down below 1.230" won't have much life left, especially as these specs were written for cars that used organic brake pads, not the newer semi-metallic and metallic pads.
Also, the original rotors will be riveted to the hubs. My understanding this was done to facilitate assembly on the production line. It is necessary that the rotor stay with the TA it was trued up on and indexed as it was when trued. If it was bolted on the hub, in assembly the line guy would have and to pull the lug nuts before putting the tire on, and extra step. So instead, the rotors were riveted in place. But after that, if the rotor is removed, for servicing, which requires drilling out the rivets, and then either refinished or replaced, it is not necessary to rivet them back into place. They can just be held on by lug nuts until put on the car, the nuts then can be pulled, and the tire put on. All that is necessary is to ensure that if the rotor is removed after being trued up to the hub, that it be put back on with the same indexing which it came off. There's no need to rivet it on and then someday having to drill out rivets to replace it.
And that is pretty much everything I think I know about TA rebuilds.
As for my 80', it still has the original rotors which have all been resurfaced once after about 90k miles. So not knowing your mileage I can say if the rotors are original, but they may be. On the other hand, some restorers such as Bairs will rivet them on unless you tell them not to.
On the topic of organic pads, a lot of folks will likely note they don't brake as well as semi-metallic and metallic. I agree if they are wet. But the brake design in the C3's is excellent including the very large pad surfaces which do a far better job of dissipating heat as compared to the smaller pads on other cars. My brother's 79 280 ZX pads were minuscule in comparison. The braking on an these cars with original equipment is enough to give you a head rush, literally. Hit the brakes at 60 or 70 and ride them to a full stop just short of skidding and you'll get a little dizzy. The short coming of organic is when they get wet. But most C3's only get wet if the weather forecast is wrong.
