What should I use?
Old Dec 19, 2002 | 11:09 AM
Gotta Fix my '76's Avatar
Gotta Fix my '76
Default What should I use?
I am going to reinstall the interior very shortly, and does anyone know what a good caulk is that I can use to seal it...There was some sort of clear silicone on their when I took it off...Is that something that is done regularly, or is it another signature bubba trait...Anyone??
Old Dec 19, 2002 | 11:22 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: What should I use? (Gotta Fix my '76)
where was it? im assuming that its an adhesive to keep the insulation down. but im not sure.
Old Dec 19, 2002 | 11:26 AM
Gotta Fix my '76
Default Re: What should I use? ('79ProwlerOrange)
It was used all over, but it was in almost ever area where the interior pieces touched the car...at the Rear quarter panels, the t-top sections and the side moldings...all along those parts...Thanks for any input.
:yesnod:
Old Dec 19, 2002 | 11:28 AM
'79ProwlerOrange
i will have to check mine. i personally am scraping all the crud out of the interior, and doing 3 layers of sound deadener, plus factory insulation, and carpet. mine should be sealed up pretty good. :cheers:
Old Dec 19, 2002 | 11:43 AM
Gotta Fix my '76
Yep, sounds like you'll have it pretty much submarine proof :-)
Thanks for the input, let me know if your going to seal any part of that interior and if so, what are you using...Thank you
Old Dec 19, 2002 | 11:47 AM
'79ProwlerOrange
the stuff im using is a cheaper than, better version of dynomat. and its actually paint. im going to roller it on in 3-4 coats, and use a spray gun to do the doors. ive heard that it drops interior SPL of a running car as much as 10 decibels. :eek: thats getting into mercedes land. at least if my exaust gets quieted down :D ill let you know what i see, i may be up there today.
Old Dec 19, 2002 | 11:51 AM
'79ProwlerOrange
forgot, i have to plug the stuff im using right? :crazy: http://www.b-quiet.com good stuff.
[Modified by '79ProwlerOrange, 9:52 AM 12/19/2002]
To What should I use?
