Sputtering out, wont stay started
Old Aug 22, 2021 | 02:50 PM
rjsuydam@msn.com's Avatar
rjsuydam@msn.com
2nd Gear
Default Sputtering out, wont stay started
My 1982 will not stay started. It will idle for a few seconds and then shut off.
So far I have:
Replaced fuel filter
Cleaned fuel injectors
Cleaned throttle body
Replaced EGR valve
Replaced cap and rotor
The only thing else I know to do is replace the fuel pump.......is there something I am missing?
Please advise......Rich
Old Aug 23, 2021 | 10:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rjsuydam@msn.com
...is there something I am missing?...
Have you checked the computer for error codes?
Old Aug 23, 2021 | 12:24 PM
Mrvettenick's Avatar
Mrvettenick
What do your plugs look like? Does it restart easily? Looking to determine if it's fuel or spark related.
Old Aug 24, 2021 | 09:15 AM
rjsuydam@msn.com
2nd Gear
Plugs look good,,,,,
Old Aug 24, 2021 | 09:25 AM
Mrvettenick
Without knowing anything else, if your plugs are clean, then I would check fuel pressure/fuel pump operation. You should have 9-12psi. One other test you can run is while someone is cranking it, try spraying carb cleaner into one of the throttle bodies to see if it starts or at least sounds better. If it starts, then for sure it's a fuel supply issue. One other item to be aware of is if the TPS is sending a high voltage signal, like 3.5 volts or higher, the ECM will go into a clear flood mode, and shut off the injectors. You can bypass that by disconnecting the TPS, if you think that's the issue.
To Sputtering out, wont stay started
