Electrical issue in 1980 C3
Old Aug 26, 2021 | 10:19 AM
mtydings's Avatar
mtydings
Default Electrical issue in 1980 C3
I have installed new dash wiring, and had a new stereo put in our 1980.
I was driving with the windows down and a CD playing, all was good. However when I turned the AC on (after getting new belts so the AC belt wouldn't squeal) then the stereo and power windows would quit working. When I switched the AC off then the stereo would play again and the power windows would work.
It is not blowing fuses. But it did drain the battery, the stereo was still on when I turned it off. The next day it would not start, I had to charge the battery.
It seems there isn't enough juice to power the AC AND the CD player, along with the power windows being able to operate.
What do you think the problem is and most importantly the solution?
Thanks!
Marty
Old Aug 26, 2021 | 01:54 PM
MelWff's Avatar
MelWff
Who installed the radio?
Sounds like they did some faulty wiring, the stereo should not be draining the battery unless it is old or the alternator is not sufficiently charging it.
When you say AC, do you mean the fan is not working or it is working and not blowing cold?
Old Aug 26, 2021 | 02:27 PM
Mrvettenick's Avatar
Mrvettenick
Check your voltage at the battery with the engine running, Then turn on the radio, then operate the windows, then finally the a/c. What is the voltage reading at the battery with all 3 turned on? If it's less than 13 volts, then your alternator is suspect. If it has weak diodes, voltage will probably be a lot less than 13.
Old Aug 26, 2021 | 04:02 PM
L-46man's Avatar
L-46man
Is the A/C compressor and brackets GROUNDED TO THE CHASSIS FRAME? KGG...KNOWN GOOD GROUND?????
Old Aug 29, 2021 | 08:18 PM
mtydings's Avatar
mtydings
I do not know but good question, I hope to find out this week when we do some testing.
Thanks!
Old Aug 29, 2021 | 08:25 PM
mtydings's Avatar
mtydings
We will check on those items this week. I am suspecting the alternator and that is a great way to be sure, thanks!
Old Aug 29, 2021 | 08:34 PM
mtydings's Avatar
mtydings
A guy I had do a lot of work on it installed the stereo. He put the new interior in for me and replaced power window and lock wiring, etc etc.
The AC just won't let the stereo or power windows work when it is on. The CD will be playing and I'll turn the AC on and it will not the stereo off along with the power windows, AND it doesn't blow much anyway. Checking the alternator this week. It has been so hot I have not messed with it this week. But next week will be much cooler so it will be time to get back to it. Thanks for the help!
Old Aug 30, 2021 | 07:43 AM
Richard454's Avatar
Richard454
Sounds like you are missing the ground on the fan blower motor.
Richard
To Electrical issue in 1980 C3
