Million dollar question about oils...
Old Aug 29, 2021 | 02:14 PM
panic's Avatar
panic
Default Million dollar question about oils...
Which is the best for a carbed 500hp 454 engine?
Fully mineral or fully sint?
Popular Reply
Aug 30, 2021, 08:10 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby
Old Aug 29, 2021 | 02:41 PM
76strokervette's Avatar
76strokervette
Synthetic oil is superior the thing you must decide is it cost effective for what you are doing?
Old Aug 29, 2021 | 02:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
You still have horses in Italy?
All ours have been beat to death by trolls.
See sticky on main page about thousands posts on oils. Your carbed engine has no reflection on oil nor does the cubic inch or H.P.
Its immaterial.
Old Aug 29, 2021 | 03:54 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Oh no.....another oil thread.
Old Aug 29, 2021 | 04:09 PM
69L88's Avatar
69L88
With 500 HP, I am presuming you’ve got a high lift cam. If that is indeed the case, you will want a high zinc content oil to deal with all of the higher valve train loads that come with the higher lift cams.
Do read the sticky on oils. There is a ton of research/experience/information available there. I have a 500HP 427 with solid lifters and I run Brad Penn (PennGrade1) 20w50. It’s ZDDP level is 1500 ppm.
Old Aug 30, 2021 | 08:10 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby
Old Aug 30, 2021 | 12:11 PM
panic's Avatar
panic
Originally Posted by Jebbysan
Jebby
Old Aug 30, 2021 | 12:39 PM
domenic tallarita's Avatar
domenic tallarita
Seems that Rotella and Delo are the choice and Walmart was the best price! They have the zinc.
Dom
Old Aug 30, 2021 | 02:02 PM
Mrvettenick's Avatar
Mrvettenick
Flat tappet or roller cam?
Old Aug 30, 2021 | 07:17 PM
How Are You's Avatar
How Are You
Semi synthetic
Old Aug 31, 2021 | 12:11 AM
ebbnflow's Avatar
ebbnflow
Dom
while on the oil aisle, look at Motorcraft Diesel ... its label actually tells how much P ... Where P goes, Zn typically follows ... price is right too.
Old Aug 31, 2021 | 07:34 AM
jb78L-82's Avatar
jb78L-82
I will try and answer your question generically.
You want a High zinc oil, ZDDP, with at least 1200 PPM in my opinion, with 1,000 PPM ZDDP, being the bare minimum and too low for me.
If you can find a synthetic oil with high zinc content that is the way to go all day long and hands down over any conventional oil of similar zinc content. In Europe, I would imagine your best bet is Castrol Edge which I use in all my cars and power equipement including my 10C6Z06 and 78 C3 355 L-82 BUT with a roller cam, 0W-40 European Formula. If you can find Valvoline Racing, synthetic or conventional Racing oil, this oil will be a choice as well, either synthetic preferably or conventional if synthetic is not available.
Diesel oils would not be a choice, in my opinion, for obvious reasons (diesel engines are very different than gas) unless that oil is the only one available, regardless of the price.
Old Sep 1, 2021 | 12:45 AM
panic's Avatar
panic
Thanks, very usefull.
I think Castrol edge would be it.
Old Sep 1, 2021 | 10:08 AM
Mr D.'s Avatar
Mr D.
The $1 answer --> Walmart Diesel Oil
Old Sep 1, 2021 | 01:28 PM
panic's Avatar
panic
What is the oil capacity of a classic carbed 454?
Old Sep 1, 2021 | 02:01 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
5 quarts most likely.
Old Sep 1, 2021 | 02:32 PM
HeadsU.P.'s Avatar
HeadsU.P.
No Walmart in Sorrento.
To Million dollar question about oils...
Old Sep 2, 2021 | 05:14 PM
Mr D.'s Avatar
Mr D.
Panic has diesel powered fishing boats pulling up to his fish store daily, just barter some fish heads for some spare diesel oil.
Old Sep 3, 2021 | 07:26 AM
panic's Avatar
panic
Seriously, I forecast fishing will be forced to stop in the next decade or so, too many regulations, laws, green lobbies trying to **** the whole industry...
I forecast the oceans and seas will become a huge aquarium where to see and dont touch gonna be the rules.
Old Sep 3, 2021 | 08:06 AM
Purple92's Avatar
Purple92
i can not argue against a high ZDDP oil for a non-roller cam motor. If however - you are using a roller cam - I see NO reason to use non-synthetic. These days there really isn't much of a price difference between dino oil and full synthetic, and there really isn't anything dino based oil does better than full synthitic - with the exception of being available with higher ZDDP levels.
I've attached a link to a lengthy discussion from fourm member 540Rat - I think he's covered the issue quite well.
https://www.corvetteforum.com/forums...test-data.html
