trigger wire
Old Aug 31, 2021 | 05:46 PM
l82vett's Avatar
l82vett
Default trigger wire
I need to hook up a 12 volt trigger wire to a relay that comes on with the key on my 1980 L82 . Any under the hood or a easy find under the dash. My back doesn't do upside down contortions to well.
Old Aug 31, 2021 | 05:53 PM
derekderek's Avatar
derekderek
removing the driver's seat is a must for any dash work. pretty sure there is a keyed spade terminal on fuse box under the dash.
Old Aug 31, 2021 | 06:11 PM
Richard454's Avatar
Richard454
You can use the yellow wire off the wiper.
However- it's hot in ignition but not if the starter is engaged. And it's on in ACC position as well.
Richard
Old Aug 31, 2021 | 08:10 PM
l82vett's Avatar
l82vett
Thank you Richard for that info. I went and checked that wire, sure enough , hot with the ignition on. Tapped into it and it worked out just right. Saved on a Chiropractic visit for sure.
To trigger wire
