68 trailing arm shims
Any insight and/or pictures of this project would be greatly appreciated.
So you need to drill a hole on each side of the trailing arm pocket and install the long cotter pin, photos:
I thought the biggest part of this PITA job was access and this helped:
I think it might be best to wait until you get the TA back and trial install with some shims to get the new shim cotter pin hole in just the right place.
Hopper12 (?) did this job recently too, so you might do a search here to learn more.
Hope this helps.
I don’t have a 90 degree drill adapter, but can understand one would make the job much easier. Always looking to buy new toys.
As for the shims, thinking to replace with SS. They only come in 3 thicknesses? My current non SS ones appear to be 3 different thicknesses.
Not to be confused with the small cotter pin in the bolt.
One pack of shims in whatever size they offer will be enough. You can use the 'trailing arm' bolt as a guide the locate the hole position, you don't want the T/A installed to do this.
Agree, locating and drilling the cotter pin holes will be easiest with the TA out. Assume you align the shims against the TA bolt and clamp the shims to the pocket side to hold tight during drilling?
use 1 style old 2 hole shim on either side of the bolt. You can put this is and it never has to come out for alignment. Use the updated slotted shims for alignment then wire tie them to the 2 hole shim. Can’t come out then.
I will also say there are likely plenty of c2s and early c3s with slotted shims and no cotter pin. Ans they haven’t fallen out
Here's the end of the T/A bolt with the castellated nut and small cotter pin.
You can see the end of the big cotter pin and the shims in the pocket.
Withy the T/A bolt installed and a shim installed on the outside of the bolt you'll find where the hole goes.
On the final installation install the pin from the inside to the outside not the way you see it in the picture.
How tight do you make the castellated nut to assure it holds the TA in place without binding up the bushing?
There are a number of posts here and on the internet on this whole job, Great photos above too. Hope this helps.
Was thinking to use the original shims and cut out the holes to create slots. That said would the shims extending outside the TA pocket create a problem with the cotter pin drilling and placement?
Ob final assemble the 'pocket' will be packed tightly with shims so that you do not crush the 'pocket' when you tighten the nut and bolt.
Couple of thoughts; first, has your rear end been aligned as the shim size might change with a new alignment?
2nd if you believe your alignment is good with the original shims, you could cut the original shims to the slot shape by seeing how far you need to cut with a trial fit with a pivot bolt as Peterbuilt says. Or using a newer slotted shim as a pattern. That will be a lot of cutting compared to how cheap TA shims are. I last used some steel ones and painted them if you do not want to splurge for SS.
My 2 cents. Will see if I can find my old 2 hole 68 shims and compare to slotted.
BTW, good advice from Peterbuilt, on the first TA rebuild I did, I did not pack the pocket with shims and fortunately realized before doing any damage. the pocket will bend in when torqueing the pivot bolt if the pocket is not packed
The bushing bolt will be fully packed with shims regardless of using old cut shims or new slotted shims eliminating any potential pocket crushing. Was just concerned when I slot cut the old shims the back end would continue to be outside the pocket and potential back out regardless of the cotter pin. Makes sense the new shims might be the same length with deeper slot cuts that allow the back ends to tuck inside the pocket eliminating any potential back out regardless of the cotter pin.
FWIW:
The 2 hole original 68 OEM trailing arm shims are 4-3/4" long and 1-1/4 wide.
The newer 69+ trailing arm shims are 4-1/2" long and 1-1/4" wide so the newer shims are a 1/4" shorter.
My C3 had never handled as well as it did when he was finished. I was amazed at the difference after the alignment. So I took my C3 home and the next day I brought over my C4, I wasn't going to miss out on this kind of service. I also tipped him more than the alignment cost by itself just for the C3 alignment. He deserved it as it was important to him to do the job the right way!
Hope this helps.
* As stated, easier to do with the TAs out, but you could do it with them in if you jack them up out of the way I suppose.
* I used cobalt drill bits, dipped them periodically in a cap with WD40 in it, and they drilled the relatively thick frame material no problem. The right drill bits and some lubrication/coolant make a big difference.
* The pic from Peterbilt is a great one too - shows you where to make the holes. I put a TA bolt in place while the TAs were out to help locate the shims just to be sure.
* I now wish I had drilled my holes just a bit lower, but they are working just fine because the holes thru the shims are large and allow the shims to drop lower than the holes.
* A couple of long cotter pins come with each set of shims. I bought two sets so I had enough different thicknesses and a couple of extra cotter pins.
* Drive the shims in on each side, trying to come close to matching the number of shims you took out on each side. I wasn't able to put in the same number of shim as I took out - probably because the TA bushing was a bit longer than the old one. Make sure you drive them in before you drive your car to the alignment shop.
* I had a bit of trouble getting the shims in on the inside of the newly rebuilt TAs, but jacking up the TA did the trick and I was able to get them in. In hindsight, I would have been better off driving the shims in prior to installing the spring, camber stuff, etc.
Your alignment guy will thank you for the change. This is one of the crazy C3 '68 only gifts that we deal with.
I just got mine started up on Monday, and have driven it around the block a couple of times because I did lots of other things to the car and I want to be sure it's all good before I take it in for alignment.
Best! Paul
