Skinny front wheels
Old Sep 4, 2021 | 02:53 PM
pewter-FRC's Avatar
pewter-FRC
Default Skinny front wheels
15x4 what backspace are u guys running to clear stock calipers? 1.75 or 2.25
Old Sep 4, 2021 | 04:57 PM
Gunfighter13's Avatar
Gunfighter13
1.5" BS with -25 offset Weld RT. The Centerline wheels are 3.5" wide with 1.65 BS and -15 offset. Don't know if that will help you. Have been using 17" X 4" front wheels for a while now on the drag cars with 16" beadlock wheels on the rear.
On my 82 I have some old Centerline 15" X 3.5" with M&H drag radials on the front and 15" X 10" with M&H slicks 27" X 9" on the rear.
Old Sep 4, 2021 | 05:25 PM
pewter-FRC's Avatar
pewter-FRC
what’s your back space on the 15 X 10’s
Old Sep 4, 2021 | 05:47 PM
Gunfighter13
They are 4.25" BS.
Let me add that they are the old Pro wheel which is a vintage wheel not made anymore. Centerline will still repair them but does not produce them any longer. I have found that most wheel company"s like Centerline and Weld will make almost any back spacing you want as long as you don't mind the cost and time it takes them to build the wheels.
Old Sep 4, 2021 | 06:11 PM
pewter-FRC's Avatar
pewter-FRC
They are 4.25" BS.
hoping an off the shelf 4.5 bs will work. I can always add a quarter inch spacer if I have to
Old Sep 4, 2021 | 06:16 PM
Gunfighter13
I've seen people here posting wheel and tire setups with 4.5" BS, so maybe they will chime in.
To Skinny front wheels
