Half shaft removal
Old Sep 5, 2021 | 06:22 PM
1eddielee1's Avatar
1eddielee1
Default Half shaft removal
Can I leave the car on the tires on the floor after removing the half shafts and drive shaft?
Old Sep 5, 2021 | 08:58 PM
kansas123's Avatar
kansas123
Welcome to the forum. If you still have the strut rods attached you might get away with it. I wouldn't do it myself.
Old Sep 5, 2021 | 08:59 PM
1eddielee1's Avatar
1eddielee1
Ok thanks
Old Sep 5, 2021 | 09:17 PM
sjr1971's Avatar
sjr1971
DON"T DO IT ...... the half shafts are the upper main brace of the rear suspension. I hit a pot hole , it broke the universal next to the differential. The driver side wheel collapsed .
Peterbuilt's Avatar
Peterbuilt
You need to buy or build this tool to change the U-joints.
https://willcoxcorvette.com/catalogs...alf+shaft+tool
Old Sep 5, 2021 | 09:19 PM
1eddielee1's Avatar
1eddielee1
Old Sep 5, 2021 | 09:33 PM
69L88's Avatar
69L88
I don’t think he plans to drive the car with the halfshafts removed.
You will have no issues with the car on its wheels static, with the shafts removed, assuming the strut rods are still attached.
Old Sep 6, 2021 | 10:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
it may be a hassle getting to all the bolts that way. Do you not want to jack it up? YOu can jack it up by the differential and put jack stands at the front of the trailing arm at the frame in case it falls. I just find getting all those bolts out easier if I can turn the wheels
Old Sep 6, 2021 | 12:30 PM
1eddielee1's Avatar
1eddielee1
I was going to jack it up and take the shafts off to get balanced and ujoints and set it back on the ground so I can move it if I have to by pushing it.
Old Sep 6, 2021 | 04:58 PM
Rescue Rogers
not sure how wobbly that would be...the only thing keeping it from twisting would be the strut on the bottom and the shock
Old Sep 6, 2021 | 08:10 PM
1eddielee1's Avatar
1eddielee1
I just going to leave it in the air. Thanks everyone 😎
To Half shaft removal
