Auto to 4-Speed Yoke Question.
Old Sep 6, 2021 | 08:51 AM
Cavu2u's Avatar
Cavu2u
Default Auto to 4-Speed Yoke Question.
Here is the TH400 yoke removed from the '73 Driveshaft.
Can someone point me to a seller for a direct replacement yoke with the 27-splined M20 Transmission? Hopefully a vendor on this site.
Thanks much.
Steve
Old Sep 6, 2021 | 09:08 AM
69L88's Avatar
69L88
Try Denny’s Driveshaft, Modern Driveline, Silversport.
Old Sep 6, 2021 | 09:12 AM
Cavu2u's Avatar
Cavu2u
Thanks my friend.
Have a good Holiday.,
Steve
Old Sep 6, 2021 | 11:42 AM
GTR1999's Avatar
GTR1999
The TH400 yoke uses a 1330 u-joint. The M20 27 spline most likely will be a 1310 u-joint. I believe the later Muncies used a 1330 yoke but had a 32 spline main shaft.
You can use a conversion joint or replace the diff pinion yoke to match.
Old Sep 6, 2021 | 01:16 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Driveshaft Specialist
http://www.driveshaftspecialist.com/...tte-Cobra.html
Remember, it's a good idea to have your driveshaft re-balanced after a yoke swap.
Old Sep 6, 2021 | 02:08 PM
Cavu2u's Avatar
Cavu2u
Without question, I'll remove it and have balanced with new yoke installed.
Thanks much.
Steve
To Auto to 4-Speed Yoke Question.
