AC Delco PF 25
Old Sep 7, 2021 | 02:31 PM
wngtym's Avatar
wngtym
Navigator
Default AC Delco PF 25
On Rock Auto they have PF 25 oil filters for $7.29. When getting ready to place an order for a couple of them i noticed it says WITH OUT Anti Drain Back Valve. Does the 1975 Corvette need an anti drain back valve or would it be ok to use these in the 350 engine? I have concerns about this and am clueless. Your thoughts suggestions would be greatly appreciative.. Thank You.
Old Sep 7, 2021 | 04:06 PM
mbp's Avatar
mbp
Hi. I would think an Anti Drain Back Valve is not needed on our 350. The filter is upside down, "in and out" at the top of the filter and basically full of oil so it can't drain anywhere and won't need to be refilled on start up. One less thing to fail. If that is the correct purpose of an Anti Drain Back Valve.
Old Sep 7, 2021 | 04:42 PM
ebbnflow's Avatar
ebbnflow
If you dismiss effects of capillary action and/or siphon, an ADBV ain't so special. I prefer with ADBV but without relief valve.
You can buy a damn good WIX (with or without ADBV) for same $ or less.
Old Sep 7, 2021 | 06:13 PM
3X2's Avatar
3X2
I use a good olde fashion GM PF35L filter.
Old Sep 7, 2021 | 06:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
The Anti-Drain feature is needed when the filter is at a 45* angle or more.
You will see this on modern cars & trucks and some old Fords where the filter attaches to the block almost horizontal. The oil could actually drain back into the pan leaving it empty at start-up..
Not even close with SBC & BBC vertical filter.
Old Sep 7, 2021 | 07:30 PM
wilcar's Avatar
wilcar
Some PF25 filters are sourced from china. Go with Wix!
Old Sep 8, 2021 | 06:30 PM
wngtym's Avatar
wngtym
Navigator
Thanks for all the feed back. I now have knowledge of the ADBV...I will give the PF35L a try as suggested... Thanks again.
Old Sep 8, 2021 | 09:56 PM
ebbnflow's Avatar
ebbnflow
That should serve you well. As will WIX 51060
Old Sep 9, 2021 | 01:03 AM
SEVNT6's Avatar
SEVNT6
Some places have superseded the AC PF 35 with PF 1218...
Old Sep 9, 2021 | 04:49 AM
Gunfighter13's Avatar
Gunfighter13
For Synthetic Motor Oils
WIX 51060XP
For non-Synthetic Motor Oils
WIX 51061 (copy of PF35L)
Places like Rock Auto still have the PF35L filters for around $9.
Old Sep 9, 2021 | 06:15 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Around 20 years ago, right before Kmart went out of business in my area, I bought their entire stock of these. I had no issues for PF25 filters, probably have 40 of them still on the shelf it should last my lifetime
To AC Delco PF 25
