383 Roller block conversion
Jebby
Huh?
Every 1-piece rear seal engine is externally balanced on the flywheel from the factory with the same weight.
Every 2-piece rear seal crank from the factory has an irregularly shaped flange behind the seal that has a heavy side, which of course acts as a balance weight because it's not round and even.
Every 2-piece rear seal 400ci engine is externally balanced on the flywheel from the factory with the same weight.
IF you are balancing a 383 2-piece or 1-piece with an externally balanced flywheel then you use the stock weight. You don't use some other weight. As long as you buy a properly built flywheel with the stock weight it will work.
Manufacturers make flywheels that duplicate the factory weight for both the 1-piece and 2-piece rear seal engines. They also make neutral balanced flywheels for both. All you need to know on a built engine is if you should use a neutral balanced or weighted flywheel.
The above is nothing new, it's the way it has always been.
A 2 piece rear main seal 383 external crank has about 70 more ounces of weight out near the gear slinging around. The weight on a 1 piece seal crank is strictly there to compensate for the round crank hub. You yourself said that there is a weightless 1 piece seal flywheel and there is....but not from the factory. So, the added weight is in the rear counterweight. And it is important to have the correct flywheel. This is all I am saying. What baffles me is that if they (Scat/Eagle) are able to compensate for 70/80 oz. of weight that is missing in the 1 piece setup....why don't they change the counterweight on the 2 piece as well so you can just run a neutral flywheel/flexplate?
There are many who balance external stuff to their "shop" flywheel and damper......the Pro's do not and will not. In fact, many won't even balance an external period. Eagle and Scat quit doing it due to returns...they include the flexplate it was spun with and in some cases the damper. You want to gamble....fine, but I will not. Even as far back as the 90's.....if a customer jacked up a flywheel on one of these external assemblies...the new one would be sent with the old one to confirm it. I have seen brand new Pioneer flywheels that have to be drilled to match an existing assembly. It is just good practice and attention to detail.
Jebby
The best way is to use zero balanced parts and then it's an easy check to ensure that a replacement flywheel is correct, but for a mild engine it's acceptable to assume a factory weight is OK and swap between parts. Not all engine build are high dollar race engines. If you pulled a low mile L31 from a pickup would you check the balance before swapping the stock weighted flexplate that was on it for a stock weighted flywheel, or would you just bolt it on and run it?
Here is a balanced Scat kit requiring an external weighted flywheel that is not included. They don't have many options but they do sell them.
https://www.summitracing.com/parts/s...make/chevrolet
Scat only sells externally balanced kits that include a flexplate, not a flywheel. If you want a flywheel go internally balanced when buying the engine kit or else you have to match balance the new to the old or you have to just change it and run it.
There are lots of 2-piece rear seal internally balanced 383 kits available from Scat.
https://www.summitracing.com/search/...nce%3Ainternal
This is all fun to speculate on, but if you buy a complete already built 1-piece rear seal engine and if it requires the external weight it will either come with a flexplate or require you to use use a factory weighted flexplate or flywheel. In all cases, if you require a flywheel then you would have to either match balance it to the supplied flexplate or just install one with a weight and run it. No-one catalog builds 383 engines with flywheels.
I know the 1 piece weight is smaller......because the rear counter weight is bigger. They had to.....nobody makes or would make a flywheel/flexplate with extra weight on it.....so they modified the counterweight. Even though the 1 piece is technically "external" is not balanced to the same numbers as a 2 piece external......confusing I know...and irrelevant so i will leave it.
As far as crate engines not coming with flywheels/flexplates for external.......it is part of the reason I would never recommend someone elses build like that. If you bought one from me......it would have the very balancer and flexplate the crank was balanced with on the engine when you pick it up. Everyone will say what I am saying doesn't matter until one guy gets a shaker......
I don't want anybody bringing anything back to me....so I just dot more I's and cross more T's I guess.......
As far as GM's balance......their assembly line spec is + or - 50 grams......so any differences in flywheel weighting are negligible compared to the + or - 2 grams the Pro Shops use. There are L31 350's out there that run silky smooth and others not so much.......the ones that shake a bit are never noticeable to the owner as there is not another to compare it to.....it may not shake much, but it does. A guy who hands me 5k to build a budget 383 will feel that type of shake like it is in their soul.....
Oh well.....good conversation and thanks for listening to my side of it!
Jebby
Jebby
Dan
Dan
Jebby
Crankshaft The ZZ383 Engine comes with forged crankshaft part number 12489436. The crankshaft features are outlined below:
- 3.800" stroke
- Externally balanced
- 2.45" main journals/2.10" rod journals
- Radii on main and rod journals
- One-piece style rear main
- Number 1 and 4 crank pins hollowed
- Rod and main oil hole chamfered
- 3.000" crank flange bolt circle
- 4340 steel alloy, nitride treated
Taken from https://www.chevrolet.com/content/da...e-19301295.pdf
- 3.800" stroke
You missed where he said the machine shop neutral balanced his rotating assembly
They DO make 100% neutral 1 piece flywheels/flexplates......but unless the assembly was balanced specifically that way....it is not correct to use. It can be confusing as hell....and I have seen many get it wrong.
If the 1 piece crank was balanced for a neutral flywheel.....it would be balanced without one at all..... Consequently, the 1 piece setup has to be balanced with a flywheel/flexplate if it balanced to GM spec.....
Now this is at the discretion of the guy balancing the crank too......some "external" cranks will balance without the weight at all.....some will not. Just pay close attention to detail on who did what. Get a balance sheet and/or talk to the guy who actually balanced it. If it is built by GM, go with their recommendation.
Jebby
Jebby
I'm in this boat currently as I am doing a 383 Forged rotating assembly on a Vortec block, so it will be internally balanced in the 2pc sense, so I will be able to run a neutral balance flexplate and a fluidampr. The local machine shop I am using leaned towards a Scat Crank instead of an Eagle to make the balance job easier.
You did post that the flywheel was zero balanced in your last post, and now you're saying it has the weight. Zero balanced was wrong, but having the weight is right.
Your are correct that lots of aftermarket manufacturers make flywheels with provisions for a bolt-on weight to change it between zero balanced and externally balanced. When you buy one of these you get the weight and can add or remove it depending on your needs.
