L31 Vortec based engine build.
Old Sep 29, 2021 | 10:39 AM
  #41
ebbnflow's Avatar
ebbnflow
What if ... the yet to be known piston sits 0.025" Below an OE deck ... and 0.015" Below your deck cut 0.010" ?
Nominal 0.040" Quench - 0.015" = 0.025" (gasket).
Seems 501 SD is about 0.0415" thick ... that would yield a large & ineffective quench of 0.0565" nearly 0.057"
If you desire a Composite gasket (like 501SD), suggest thinner (0.026") Mahle 5746:
Nominal 0.040" Quench - 0.015" = 0.025" (gasket). ... But with 0.026" gasket that would yield a decent quench of 0.041"
... or deck it 0.011" & yield 0.040" quench
... or deck it 0.012" & yield 0.039" quench etc etc
GM 10105117 is quite similar Composite but 0.028" thick and is OE on many performance motors.
* all the above based on a piston which sets 0.025" Below a stock, Uncut deck.
Old Sep 29, 2021 | 11:39 AM
  #42
ebbnflow's Avatar
ebbnflow
Again, my experience tells me cleaning via "Bake & Blast" far superior to hot tank. When B&B, ya cannot tell it from brand new.
Old Sep 29, 2021 | 12:54 PM
  #43
C6_Racer_X's Avatar
C6_Racer_X
This is good information, up to a certain point. It also depends on the chamber volume in the heads he's using.
I've found that most of the FelPro gaskets are almost like they're designed to get an engine back to stock compression, stock pushrod/rocker arm geometry and other stock specs after milling the heads and/or the block deck a total of 0.010" to 0.015". For someone doing repairs on a stock engine, that's often perfect because it "puts back" everything that was taken off in the machine shop. But when "designing" (or modifying) an engine for a specific purpose, with specific goals in mind, the FelPro gaskets aren't usually my first choice.
Old Sep 29, 2021 | 02:50 PM
  #44
ebbnflow's Avatar
ebbnflow
fwiw, mahle 5746 (fka victor reinz, aka Napa, fka clevite)... used lotsa times in 10:1 CT race 350/355 ... CT stresses any motor ... 5746 holds up w/ no problem, no issue. Nice price too.
I like $80 gaskets; but if I know a $20 piece lives & works just as well, then I'll go with the bargain.
JMO. Only deck as much as is required to Primarily clean up decks, Secondarily achieve proper quench. If ya zero-deck a motor to begin with, you won't have anything left to cut if you damage a deck later on. Ideally, choice of piston and chamber volumes are for setting compression; not gasket. Plan & execute as a whole package. YMMV
Old Sep 29, 2021 | 03:57 PM
  #45
djquik1's Avatar
djquik1
It is really going to depend on how much gets taken off to clean it up. The heads I am using have 64cc combustion chambers. The other thing will be lift, leaning towards the gm847 cam currently and a 1.6 rocker, I also have to worry about Valve to piston clearance with a 6" rod being a factor. Thicker gasket will help in a few aspects. I called the machine shop and he thinks it will take a .020 cut to clean it up. That leaves me .005 above zero deck height.
Still trying to figure out several things on pen and paper before pulling the trigger,
Old Sep 29, 2021 | 04:28 PM
  #46
ebbnflow's Avatar
ebbnflow
Please don't sacrifice a good quench to solve V-P clearance. Chances are, the valve reliefs aka eyebrows alone will be sufficient. Yes or No, you'll verify w/ clay.
But, if not, adequate V-P clearance is routinely attained via machinist fly-cutting eyebrows a bit.
Old Sep 30, 2021 | 12:26 PM
  #47
djquik1's Avatar
djquik1
I won't be sacrificing good quench. I am a couple months away from getting all my components at this point. Not buying a already balanced rotating assembly. Picking my parts individually and then going from there. Going with a Scat crank but not sure manufacturer on rods. We carry a lot of lines at work. So may go with someone else's rods.
Old Sep 30, 2021 | 07:39 PM
  #48
ebbnflow's Avatar
ebbnflow
congrats on picking & choosing!
Old Nov 12, 2021 | 10:55 AM
  #49
djquik1's Avatar
djquik1
Ordered the Summit racing 8803 cam today with LS7 lifters. Been working on the heads a lot lately on porting and polishing. Sadly a lot of components are on back order
Old Mar 21, 2022 | 10:15 AM
  #50
jjmccloud's Avatar
jjmccloud
2nd Gear
Following along...Any updates? Planning a similar build/rebuild myself but for my truck so have the complete L31 to start with. Although since it's been a slow stocking up of parts for a few months I won't be using much of the original engine lol but we'll see what happens when check out the rotating assembly 😅 but new top end is pretty much gathered up
Old Mar 24, 2022 | 10:04 AM
  #51
djquik1's Avatar
djquik1
I have just been gathering parts since everything seems to be on backorder at different times.
Old Mar 24, 2022 | 10:25 AM
  #52
jjmccloud's Avatar
jjmccloud
2nd Gear
I hear ya there, seems to be a chore half the time to get the parts you want. Its basically have alot of patience and qait on the things you really want or need, or settle for something else to get it done. Luckily for me it isn't a must have done thing this time so I can have a little patience lol still hard to so though. Keep us updated when you get everything going
Old Feb 28, 2024 | 04:40 PM
  #53
djquik1's Avatar
djquik1
So I am undecided on the stroker and going 383 but am moving forward with 6" forged rods. I will either be using my stock L82 forged crank and sticking with a 355, or I will get a forged 3.75 stroke crank. Going with a 1pc rear main seal to 2pc adaptor. Either way I am staying with an internally balanced set up. This engine will be in my 1979 for a while and then get transplanted into my father's 1970 with a manual trans. My car will have the Th200r4. I will install a LS down the road.
