1981 Trailing Arms Install - Continued
Old Sep 17, 2021 | 09:12 AM
TO_Vette's Avatar
TO_Vette
Default 1981 Trailing Arms Install - Continued
I'm picking up my rebuilt trailing arms today and I'm trying to figure out how best to get these Trailing Arms back installed.
Simple enough, the arms go into the frame and a bolt holds it in.
The problem is that the bolt starts inside of the frame block in this little area where it has to be feed through and into through Trailing Arm Bushings.
You only have a couple inches to work the bolts through. What kind of engineering monster designed this.
Any suggestions would be appreciated?
Old Sep 17, 2021 | 10:41 AM
antpgomes's Avatar
antpgomes
I just installed mine and followed the suggestion on this video:
Basically run a length of phishing line through the cotter pin hole to help it get started - worked like a charm
Good luck!
Old Sep 17, 2021 | 08:10 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
https://youtu.be/tHgKfGTAjj8?t=493
Good luck!
Don't you mean the pivot-bolt-hole?
Old Sep 17, 2021 | 09:04 PM
antpgomes's Avatar
antpgomes
what doorguner said!
Let us know how the installation goes!
To 1981 Trailing Arms Install - Continued
