Ordering Tremec, what else should I get?
Old Dec 21, 2002 | 11:07 PM
fauxrs's Avatar
fauxrs
Default Ordering Tremec, what else should I get?
Here is the list of things I will order from Forte's
TR-3550
Speedometer drive/adapter with gear (manual)
Yoke (63-82 Corvettes)
Backup light switch
Stock transmission mount (rubber)
plug (since I dont have a computer)
I will have the driveshaft shortened at a local shop and that will include new U-joints.
A shifter handle and **** will have to be hunted up.
Does anyone know how big a spacer will be needed on the shifter handle to locate it properly?
I must be forgetting something, what is it?
Any installation tips (especially those that do not include crossmember removal) would be appreciated.
Old Dec 21, 2002 | 11:40 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Default Re: Ordering Tremec, what else should I get? (fauxrs)
I ordered mine from Hanlon Motor Sports and saved a couple of hundred bucks.
It also came with several things that the other one charges for like the speedometer conversion.
One thing you will need to aquire is a Detachable Front Yoke from Mark Williams Enterprizes. It's about 215.00 and a must have to put a Tremec in a Corvette. This yoke also uses a 3350 U-joint so you will have to either use a two size U-joint or change the rear yoke also and make a driveshaft with 3350's on both ends. (This is what I am doing).
The shifter can be spaced or a stick may be bent to work. Any Mustang T-5 trans shifter will work. Do a serch on TKO or ask GransportC-3 where he got his from. I purchased mine from Hanlon's, I got a PRO 5.0 shifter and stick from them.
A crossmember change is part of it also.
This is just a general overview. Do a Forum Serch and there is a lot of info and more specific details available. JIM
Old Dec 22, 2002 | 08:43 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: Ordering Tremec, what else should I get? (PROSOUTH)
while your at it, get a ROD 6-speed. for me. :D
*bump
Old Dec 22, 2002 | 10:19 AM
fauxrs's Avatar
fauxrs
Did you order the 3550 or the TKO from Hanlon - Their website only talks about the TKO for GM cars - and their online catalog seems to be internal parts only. Hanlons TKO is $100 cheaper so if their 3550 is cheaper then maybe I go there.
Old Dec 22, 2002 | 11:24 AM
SteveG75's Avatar
SteveG75
I also got the 3550 from Fortes. Good people to deal with. The yoke you get from them is the take-apart kind.
The Tremec has a web on the bottom of the tailhousing that needs to be trimmed off.
The mounting pad is located the same distance back as that on a 700R4. I used a mounting bracket from Bow-Tie Overdrives but others have said that they have stopped selling that bracket.
If you have a 4spd with welded crossmember, you either have to make the crossmember removable or oull the engine and install the engine and tranny as a unit. I did this and used a Centerforce Dual Friction clutch.
Enlarge the shifter hole and cover up the old one. To make the shifter come through the stock console, I had the stock shifter cut and welded and then bolted on a shortened Hurst handle:
I have about 5000 miles on this tranny and it is great.
BTW: Mike Forte mentioned that he might start offering console plates with the Tremec shift pattern. You might want to ask him.
FYI: Other info that I found out the other night. Forte's Tremec uses a special GM input shaft made especially for him by Tremec. Another GM Tremec vendor (Dark Horse Performance in Seattle) makes their own input shafts. Don't know where Hanlon gets theirs from.
Old Dec 22, 2002 | 12:47 PM
Bob Turner's Avatar
Bob Turner
Eric,
Congrats on your purchase!! You won't regret that overdrive!!!!
Bob :cheers:
Old Dec 22, 2002 | 08:37 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
http://www.HanlonMotorsports.com/
"Hanlon Motorsports can provide you with a new T5, Tremec 3550, TKO or TKO II transmission." so YES to your question.
Includes:
- Transmission
- Rear-mount stock shifter
- Hardware
- Speedo adapter
- Standard yoke *
*Corvette requires special yoke
They are cheaper and some of the things the others charge for a free from them. So you have to consider this decreases the cost of overall purchase.
On the question about the input shaft, I considered this and the difference is that the original input shaft is chucked into a lathe and turned back just a little and down in pilot size. I couldn't see where this would create a problem.
I was very well pleased with my purchase from them. I haven't installed mine yet, I also have the Centerforce set up to go in my car. The shifter I purchased is the PRO 5.0 and it comes with a stick, very slick set up. JIM
Old Dec 22, 2002 | 08:41 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Includes:
- Transmission
- Hardware
- Speedo adapter
- Standard yoke *
Hanlon is the cheaper place to get the TKO.. even though they increased their price by $100 recently...
:cheers:
Olivier
Old Dec 26, 2002 | 09:39 AM
fauxrs's Avatar
fauxrs
Default Re: Ordering Tremec, what else should I get? (GrandSportC3)
I'll look into them closer - thanks
Old Dec 26, 2002 | 09:47 AM
Gordonm's Avatar
Gordonm
They are in St Peters Pa. I travel out there all the time. Only 1 hour away. I can save shipping costs also. I'll have to go see them. Thanks for the info.
Old Dec 26, 2002 | 12:35 PM
71roadster's Avatar
71roadster
Default Re: Ordering Tremec, what else should I get? (Gordonm)
There is also a place called Swarr Auto, somewhere in PA I think. There is a website if you do a search. Another $100 cheaper than hanlon, cheaper shipping, and MUCH quicker turnaround. Its where I got mine - yet to be installed.
Chris
To Ordering Tremec, what else should I get?
