70 350 bored 0.60 over
Old Oct 3, 2021 | 12:18 AM
Cashby j's Avatar
Cashby j
3rd Gear
Default 70 350 bored 0.60 over
I have a 70 block thats bored 0.60 over and I have 91 l98 heads what cam would be good with this application
Old Oct 3, 2021 | 12:19 PM
MelWff's Avatar
MelWff
Contact Competition Cams tech help
https://www.compcams.com/contact-us
Old Oct 3, 2021 | 01:06 PM
Jarhead 74 Vette's Avatar
Jarhead 74 Vette
Veteran: Marine Corps
Another great option would be to call Howard’s cams tech line (920) 233-5228.
They are very helpful!
Old Oct 3, 2021 | 01:28 PM
C3TPI's Avatar
C3TPI
Are you using the TPI system off of the L98 as well? Comp Cams grinds a hydraulic roller cam specifically for that application. You would need to convert your block to roller cam, however.
Old Oct 3, 2021 | 04:12 PM
ebbnflow's Avatar
ebbnflow
Is your 70 block already fitted with pistons ? Have you considered compression ratio ?
Old Oct 3, 2021 | 06:44 PM
riverracer au's Avatar
riverracer au
auto or manual?
if auto what stall convertor do you have or want?
diff ratio?
cruising on the street or racing round on a track or drag?
many things to consider when when choosing a cam, the wrong setup will be a dog to drive.....
Old Oct 4, 2021 | 10:10 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Round, because L98 heads are worth melting for beer cans.
Old Oct 5, 2021 | 07:11 PM
ebbnflow's Avatar
ebbnflow
Well ...in addition to some C4s, Camaros, and Firebirds ... L98 heads were also OE on ZZ3 & ZZ4 & x603 crates; all 3 obsolete and discontinued.
True, they don't (& won't) flow much but their small 58cc chambers are good for raising dished motors' compression; that's about it!
Their chambers are Not Fastburn design. They're also both obsolete and discontinued.
To 70 350 bored 0.60 over
