Dougs, Hedman or hookers??
Old Oct 6, 2021 | 09:16 PM
Fly skids up!'s Avatar
Fly skids up!
Default Dougs, Hedman or hookers??
I'm trying to decide on either Doug's D350, Hookers 2456-1HKR or Hedman Elite. Fitment is the most important to me. I would love to use the Hedman's for the 14 gauge tubing however I've read some reviews on them and some people had fitment issues with them. I'm leaning towards the Doug's over the hookers. I saw a picture of the underside of a C3 using the Doug's D350 on this forum somewhere and the fit looked real good. They appeared in the picture to bow out towards the side rather than going down for better ground clearance and clear the transmission cooler lines better also. So I'm probably going to go with those unless someone says otherwise. The other thing is that all of the header manufacturers fitment applications don't jive summit's or Jeg's fitment applications. I'm sure the manufacturer knows more about what fits what then Summit or jegs. But who knows? My car is 82 with a stock 350 and 700r4 transmission. Thanks in advance.
Old Oct 6, 2021 | 09:43 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Hedman Elites will, most likely, require you to dent them at the idler arm. They are nice headers otherwise. Why they can't miss the idler is beyond me.
BTW - this is on my '79
Old Oct 7, 2021 | 10:05 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I have Hedman's on my 72'......they are circa 1995 judging form the logo.....they fit perfect. In fact the reason I kept them ( they were on the car when I bought it) was because they fit so well. I had them ceramic coated and they work great......
A fella here has a pair of vintage Blackjack headers for $300 in the sale forum.....I want them but don't need more **** laying around......they are 1 3/4" tube and I know they fit from my youth.....worth considering.
Do not rule out swap meet headers or used ones.......if you see a set, check and see if there is any dents made on them......no dents means they fit the car just fine that they were on.
Doug's are very nice pieces and you pay for them......if you have the budget, buy those....but I urge you to buy or have them ceramic coated. I will never own another car without ceramic coated headers on it......
BTW...if you ever look at a header catalog.....there are at least a half dozen footnotes for every part number.......this can get VERY confusing so read carefully.
Jebby
Old Oct 7, 2021 | 10:55 AM
Hungry Bob's Avatar
Hungry Bob
I installed Doug’s side pipes last year on my 71. It was a perfect fit with no need to clearance anything. With the car jacked up high, they installed easily from the bottom.
Old Oct 7, 2021 | 12:58 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
I just got the dougs. I wanted the black coated ones but couldnt find them so I got the silver ceramic. Havent put the motor in yet but they fit the heads ok. Look well made
Old Oct 7, 2021 | 02:17 PM
Fly skids up!
Thank you to everyone. I just ordered the metallic ceramic coated Doug's D350 headers.
Old Oct 7, 2021 | 04:21 PM
ctmccloskey's Avatar
ctmccloskey
Good Luck with your new Ceramic coated headers! Fly skids up! They are something I would insist on from now on as well. They can reduce the heat under the hood and that helps a lot in a Corvette.
Check to see what the manufacturer says about Breaking In a new engine on the coatings if that applies to you. I still have a 27+ y/o set of Hedman Hedders and they fit like "glove" on the 427 and the rest of the Manual transmission parts in my C3. I never had to dent or bend anything to get them to slide right on.
The Ceramic Coatings are where I have had issues over the years. Many suggest that you do not "break In" a new engine with coated headers as it can damage the coating. I am using High Compression and it just doesn't like the Ceramic coating for about 4" on every exhaust pipe. They make better coatings for higher temperatures but they have to be done custom.
One Coating company told me that parking over "unfinished" Cement floors would cause "red spots" to form on the pipes.
Try using either the Soft Copper or Soft Aluminum Exhaust gaskets as they work better than the regular gaskets with headers.
Old Oct 7, 2021 | 04:42 PM
interpon's Avatar
interpon
Good luck! Be great to see some before after pics and temperature readings compared to oem’s
Old Oct 7, 2021 | 05:11 PM
Fly skids up!
Thank you for the tips. I have 61,000 miles on my car so I'm not breaking in. The heat was contributing factor for adding coated headers to this car. I think 82 Corvettes with the factory shorty headers is the second reason next to farting cows for global warming. (Just for the record I don't buy into the climate change BS). I will be using something better than paper gaskets. I'm also going to use a mini starter with this swap. As far as parking on a concrete floor? I don't know but that's where my car gets parked. Hopefully that's just a myth like storing batteries on a concrete floor.
Old Oct 7, 2021 | 05:24 PM
Fly skids up!
Definitely, I will be supplying all that with 1/4 time slip too. It's just going to take some time. Besides the install I will probably need to retune the ECM. I'm sure the a/f ratio is going to change. Gainesville raceway test and tune and Friday night madness only happens once a month so I won't anything post until I have a time slip.
To Dougs, Hedman or hookers??
