Turn signals light when head lights on
Old Oct 15, 2021 | 04:16 PM
73C34me's Avatar
73C34me
Default Turn signals light when head lights on
Turn signals work fine. Until the headlight switch is pulled on. Then the turn signal indicators in the gauges are lit as are the signals. Not flashing- just on. With the lights on, the signal lever doesn’t activate them or make them flash; remain on. I don’t know how long this has been going on, cause i never drive after dark. I replaced the headlight switch and have had the tilt telescope steering column apart, so theres that. Thank you for consideration. Jim
Old Oct 15, 2021 | 04:34 PM
lionelhutz's Avatar
lionelhutz
As a quick check, with the signals on see if the signals are brighter than the running lights or not. In other words, turn lights on and observe their brightness then turn lights off and signal on and observe their brightness. If you find one that is the same brightness for both then check its ground. I would suspect the grounding for the rear tail lights as the most likely cause.
Old Oct 15, 2021 | 07:21 PM
Richard454's Avatar
Richard454
The front and rear turn signals are on a separate circuit-isolated
Try disconnecting the rear harness- so you won't be chasing your tail lights if it's the front lights.
12 pin right at the fusebox
Old Oct 15, 2021 | 07:36 PM
lionelhutz's Avatar
lionelhutz
That's correct. Front lights connect to the dash indicators. So, check the front light grounds.
Old Oct 15, 2021 | 08:22 PM
GordonR's Avatar
GordonR
The issue comes from most cases a lack of ground for the bulb. When the ground is missing at the bulb for the park light circuit the power for the taller thin element will seak the least path of resistance through the heavy short thick element for the turn signal through the base of the bulb and back feed through the wiring feeding indicator bulbs in the dash lighting them up. Corroded sockets, bad socket or ground supply wiring is normally at fault.
Old Oct 17, 2021 | 10:29 AM
73C34me's Avatar
73C34me
Thanks to all for the information to diagnosis. It may be a bit before I can get to this, but I will report my findings back. Have a great day
Old Oct 18, 2021 | 06:19 PM
73C34me's Avatar
73C34me
Had a few minutes today. The bulb intensity seems fine. Pulled a front turn signal harness and bulb and ran a direct ground from the bulb to the chassis. There was no change in intensity. the ground on the driver side is good and securely fastened. I did not locate a separate ground for the passenger side, so this is the side i ran the temporary ground to. I can also say that with the turn signal "on", then activating the headlights, the turn signal continue to flash. during this process the instruments indicators flashed as though the 4 ways were on (they weren't). When i turned the flashing signals off, while the headlights were on, I could not reactivate them until I turned the headlights off.
Old Oct 18, 2021 | 06:51 PM
derekderek's Avatar
derekderek
it is the headlight ground you are missing. i think it goes to the metal piece the rear of the headlights mount to. and it is badly grounded to the rest of the car.
Old Oct 18, 2021 | 08:39 PM
lionelhutz's Avatar
lionelhutz
If you have the bulb out, the turn signal is the shorter heavier looking filament and the running light is the longer thinner filament. Check each is on only for the right function.
Old Oct 20, 2021 | 09:57 AM
73C34me's Avatar
73C34me
will do. much thanks.
Old Oct 21, 2021 | 02:56 PM
73C34me's Avatar
73C34me
update. The turn signal lights the shorter thicker filiment. The front running lights don't turn on at all. The rear running lights do.
Old Oct 21, 2021 | 03:39 PM
GordonR's Avatar
GordonR
How bright are those elements lighting up?
Old Oct 21, 2021 | 03:42 PM
73C34me's Avatar
73C34me
I would say they are appropriate brightness.
Old Oct 21, 2021 | 03:49 PM
GordonR's Avatar
GordonR
For being a running light? Or the brightness of a turn sig. (Same intensity as a brake light bulb?)
Old Oct 21, 2021 | 03:50 PM
GordonR's Avatar
GordonR
Do you have access to a test light?
Old Oct 21, 2021 | 04:49 PM
73C34me's Avatar
73C34me
Yes to test light. Test light is bright when i ltested with it. Also have a multi meter
To Turn signals light when head lights on
