1975 Quadrajet bog issue
Old Oct 16, 2021 | 01:28 AM
Jerrit1's Avatar
Jerrit1
Default 1975 Quadrajet bog issue
I bought a 1975 Corvette 4-speed. It drives fine on the primaries but if you floor it it bogs and pops and never accelerates. I can see the secondary butterflies open, both top and bottom seem to open ok.
I shipped the carb off and had it rebuilt. It looks like new now but after putting the carb back on and following all the "how to adjust air fuel idle screws" and getting the best vacuum at idle and then adjusting the idle speed the carb does the exact same thing as before the rebuild.
The car starts, runs and drives great on the primaries, if you never floor it you'd never know there was an issue.
Any thoughts on what I can try?
Old Oct 16, 2021 | 07:08 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
2 things, first...
Did Lars rebuild it. If not you may want to talk to him or buy the Cliff Ruggles book and see if there is an issue internally
Amazon Amazon
Second and good news for you, most bog issues is the air flap in the secondaries opening too fast. THere is a allen head set screw underneath the spring tensioner for the door that you cant see. You loosen that, adjust the spring so the door stays closed slightly longer and the bog will generally go away if all the jets and rods are the appropriate size. The bad news is, you say yours never accelerates after you floor it. If you slowly put the pedal to the floor so that everything opens slowly, what happens. IF you slowly transition into the secondaries that door will open slowly. If the door is the issue you will not get the bog if you go slow. If you get a bog after that then you have the wrong rods or jets in the secondaries. You would have to determine rich or lean issue at that point
If you get the book and take it apart yourself you can see the numbers on the jets and rods at that point
Old Oct 16, 2021 | 07:13 AM
Matt Gruber's Avatar
Matt Gruber
also check the base timing - i like 13-17 BTDC
and the advance curve needs to come in quickly- but not to the ping point
Old Oct 16, 2021 | 07:37 AM
Rescue Rogers
Forgot about that...Really good point. Do that first
Old Oct 16, 2021 | 07:54 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, definitely check ignition timing. I believe I went thru this once. Then when was the last tune up? I doubt it's the carb.
Old Oct 16, 2021 | 08:42 AM
stingr69's Avatar
stingr69
The secondary windup needs to be checked (after the timing is verified)
Somewhere between 7/8 and 3/4 of a turn past closed is probably in the ballpark. If it is too soft a setting, you will get a bog. Too tight and it will open slowly or not at all.
Lars also could fix it. I would just send it to him if you can't get it to work right.
Old Oct 17, 2021 | 06:05 PM
Jerrit1's Avatar
Jerrit1
2 things, first...
https://www.amazon.com/Rebuild-Modif...8&sr=8-1-fkmr1
Second and good news for you, most bog issues is the air flap in the secondaries opening too fast. There is a Allen head set screw underneath the spring tensioner for the door that you cant see. You loosen that, adjust the spring so the door stays closed slightly longer and the bog will generally go away if all the jets and rods are the appropriate size. The bad news is, you say yours never accelerates after you floor it. If you slowly put the pedal to the floor so that everything opens slowly, what happens. IF you slowly transition into the secondaries that door will open slowly. If the door is the issue you will not get the bog if you go slow. If you get a bog after that then you have the wrong rods or jets in the secondaries. You would have to determine rich or lean issue at that point
No, Lars did not rebuild it.
If I put my foot slowly to the floor it behaves the same way, at some point it just bogs and pops and hiccups. ....the bog never clears up.
Old Oct 17, 2021 | 06:06 PM
Jerrit1's Avatar
Jerrit1
Ok, thanks for the suggestion, I have not yet checked the timing on the engine.
Old Oct 17, 2021 | 06:33 PM
Rescue Rogers
Is your vacuum advance working? Is your mechanical advance working?
Old Oct 17, 2021 | 07:10 PM
Jerrit1's Avatar
Jerrit1
2 things, first...
It was rebuilt by a eBay seller named Danny Aldridge (eBayID dlataa), he is located in Aiken, SC and the cost was $125 return shipping included.
He installed a new fuel filter. I paid a little extra to replace a bad choke diaphragm? I think and then i also had it converted to an electric choke from heat pipe.
Old Oct 17, 2021 | 07:11 PM
Jerrit1's Avatar
Jerrit1
Originally Posted by lars
Timing, vacuum advance, and centrifugal advance will not cause the problem you are having. You have an air/fuel delivery problem (carb and/or fuel delivery problem).
A new fuel filter was installed with the carb rebuild.
Lars, what do you charge to look over a carb?
My 75 Corvette is just a stock L-48 engine.
Old Oct 17, 2021 | 09:55 PM
Jerrit1's Avatar
Jerrit1
I'm wondering if I'm just better off going with this....
https://www.jegs.com/i/Edelbrock/350...RoC7y4QAvD_BwE
$360 for a Edelbrock AVS2 1906 Carburetor [650 CFM Electric Choke]
Old Oct 17, 2021 | 10:30 PM
Jerrit1's Avatar
Jerrit1
You don't like Edelbrock carburetors?
Old Oct 18, 2021 | 06:57 AM
stingr69's Avatar
stingr69
The Quadrajet is the better carb by a wide margin.... Send yours to Lars.
When you get it back, you can bolt it on and run it. One less thing to worry about.
Old Oct 18, 2021 | 09:40 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Absolutely the WORST thing you can do is install an Edelbrock square bore carb on a GM spread bore intake.......then you can chase down why it runs poorly after it is installed. The mismatch that the required "adapter" creates is pretty terrible.......and it will 100% never run right.
Get the carb that came with the car repaired. Send it to Lars and see what he says.......
There is no carb that will function better than a Q-Jet on a mild 350. None.
I do a lot of them and every engine I bolt one to runs like a watch......it is crazy how well a well done Q-Jet runs.
Jebby
Old Oct 18, 2021 | 09:50 AM
Matt Gruber
Jebby
the holley 4165 is better. Had a shoot out with Lars years ago- the 4165 won.
But i highly recommend Lars- he knows qjets! Since the OP has a qjet, it will cost less to keep it.
Old Oct 18, 2021 | 09:58 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Jebby
The spread bore Holley is an excellent piece......but now about 2.5 x $$$$ of what it takes to do a nice Q-Jet......crazy.
Jebby
To 1975 Quadrajet bog issue
Old Oct 19, 2021 | 06:36 AM
Mr D.'s Avatar
Mr D.
Heed the advice of everyone here, just send your Q-Jet to Lars for a rebuild and test. You will have no regrets.
Old Oct 19, 2021 | 07:23 AM
69L88's Avatar
69L88
The last properly rebuilt/setup Q-jet on the planet will have been done by Lars.
Remember the “Porsche - there is no substitute” ads? Think “Lars/Q-jet - there is no substitute “.
Old Oct 19, 2021 | 09:35 PM
Jerrit1's Avatar
Jerrit1
Jebby
I'm not sure that's true, LARS made it very clear to me that he could fix my "junk" Q-Jet but it was going to cost me a lot.
