Rear Struts--
Old Oct 20, 2021 | 12:25 AM
TimAT's Avatar
TimAT
Default Rear Struts--
Just went thru Bman's thread on his heim joint struts. And I have a question that is related, but I didn't want to Hijack his thread.
Knowing that the "smart struts" lower the inboard strut attach point by roughly 1 inch, do the strut rods need to be shorter to compensate for the reduced angle? I'm looking at swapping the trailing arms over the winter and while it's down, building a spacer to drop the inboard struts rather than buy a complete smart strut kit that I won't use enough of to justify the cost of that and then additional cost for heim joints.
Old Oct 20, 2021 | 07:34 AM
Mooser's Avatar
Mooser
It will change but should only be something like 1/8" or so. Easily compensated but the adjustable ends when setting the camber type thing
M
Old Oct 20, 2021 | 11:59 AM
Richard454's Avatar
Richard454
I just made my own spacer ½" aluminum-
Tubes were 13.5"- used different size heim joints- 5/8" and 1/2"
I think I was all in at $150- and made my own washers - I did get greasable tubes
Greasable tube and moly ends from Out-pace Racing Products https://out-pace.com/
Cones from QSC components - https://www.qscomponents.com/
Old Oct 20, 2021 | 06:40 PM
TimAT's Avatar
TimAT
Thanks guys--
The heim joints and rods are all available locally from Rod End Supply so that part is easy. I'll make a spacer from 1" 6061-T6 aluminum bar so that part is easy. Same with the alignment. All easy stuff. I just didn't want to get "almost there" and find out it was going to be another trip across town to get the right length tubes.
Old Oct 20, 2021 | 09:13 PM
Sayfoo's Avatar
Sayfoo
Question for Richard.
I have seen the inner bracket installed 180 deg. off yours--flat edge up and the legs down.
Different brand?? Installed wrong???
Old Oct 20, 2021 | 09:37 PM
Richard454's Avatar
Richard454
It's the "smart strut" one- mine's OEM
I have thought about just getting some rectangle tubing and make a stiffer bracket -and put a jacking puck on it.
To Rear Struts--
