TKO 600 not fitting on 1980 C3
I've been working on sway from TH350 to TKO600 and have tranny installed but I'm having clearence issues to install crossmember. I got parts from SST and they sent me a bracket that supposed to mount to my crossmember to attached TKO 600 at the stock location. The original crossmember has a welded support bracket that was for old TH350 that is in the way and I don't think I have enough space even if I were to remove the bracket. I've cut a hold in the tunnel to allow transmission to go up into proper postion but still won't work. Not sure if I have to cut tunnel further forward but it looks like I'd be too high at that point and the driveshaft wouldn't clear back to differential.
I'm hoping someone here has run into this and can provide some help. I've attached some pics. I took them on my back with one hand to they aren't great. Very fustrated so I'd appreciate any advice.
TIA
Jose
Show us the whole crossmember......I *believe* that the interference you mention is with the forward facing bracket? I would have attempted to modify the crossmember before coughing up 400 bucks. Doesn't look like much interference, but then again, I cut out the welded in cross-member on my 68. Do you have a welder?
I am glad you posted close-up pictures of the ends of that automatic crossmember.... I need ideas on modifying my crossmember for installing a 200-4R. One good thing about the American Powertrain crossmember is the big path for exhaust that is has---- you can now go to true dual exhaust if you wish.
Let me find a pic of the mods that I made to bolt on the richmond 6-speed. If the interference is the forward facing bracket then I may have a simple idea for you..... be back in a sec...gotta find pictures.
I circled in the picture where the cross member bumps into the transmission. Seems like the crossmember needs to have a dip in the center where the transmission is dropping it 3-4 inches to allow the TKO and it's mount to come down a bit. I cut the hell out of me tunnel thinking that I was not up high enough but from the pics I've see from other members they fit the TKO 600 in the C3 without have to complete cutiup the tunnel. Just cutting for shifter.
Not sure what else to try.
The circle is where it bumps into transmission right behind where the mount is. So I can't puch up enough to secure crossmember.
Isn't that "hump" over to the passenger side where the exhaust passes UNDER the crossmember? Are you certain that thing is NOT bent? Flip it over and see if it lies flat?
I think your crossmember is bent up in the middle, as if someone tried to jack up the car by putting the jack in the middle of the crossmember. My car is a ‘79 but the 600 fit without all that cutting. I used the stock crossmember with a 700R4 trans bracket from an ‘82 and everything bolted up perfectly. The only modification was to reposition the parking brake pulley slightly.
I think your crossmember is bent up in the middle, as if someone tried to jack up the car by putting the jack in the middle of the crossmember. My car is a ‘79 but the 600 fit without all that cutting. I used the stock crossmember with a 700R4 trans bracket from an ‘82 and everything bolted up perfectly. The only modification was to reposition the parking brake pulley slightly.thank you!!!
https://www.corvettemods.com/C3-Corv...hoCGlMQAvD_BwE
Worked great and very easy to install using stock mounting bolts and locations.
This is the one I got from american powertrain. Although I no longer see it on the website.
but I thought we suspected your crossmember was bent? The 82 crossmember has the 700r4 mount location which should be the same as the TKO/TKX.
it’s nice to know that it may be possible … I’d prefer to use the stock 82 crossmember like the member above used …
