HEI Ignition Coil
Old Oct 29, 2021 | 10:45 AM
ebbnflow's Avatar
ebbnflow
Originally Posted by ebbnflow
WAG ...dunno, maybe it's not a design requirement to fit snugly ??? .......
Originally Posted by bmotojoe
I used your 1st photo as reference:
On my original 77 1875894 coil there is .035 movement between coil and frame, so yes there is some up and down movement.
As for rotation yes, even when coil is inserted into cap the movement is about the same .035.
Joe: did your OE coil also function AOK (with those movements) ??
Old Oct 29, 2021 | 10:56 AM
bmotojoe's Avatar
bmotojoe
Yes,
The reason I changed the Coil was during a cap & rotor replacement red side wire broke at duel male terminal.
Replaced many-many years ago with a USA made Standard DR32
Old Oct 29, 2021 | 04:37 PM
ebbnflow's Avatar
ebbnflow
JMO No EE here, but the laminated ferrous steel "frame" is the "core" and, so long as core extends thru & beyond both ends of both primary & secondary windings, I doubt if either walk or wiggle has much, if any, effect on coils' ability to consistently induce high voltage. YMMV
AUD : USD
Interesting history of Australia's Nationalized Public Health System
https://www.vox.com/2020/1/15/210305...rance-medicare
Seem quite different from most of USA
Old Oct 30, 2021 | 02:26 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
All this is interesting. my original coil died about 10 years ago. less than a block from my driveway. Neighbour guys helped me push it home. Anyway, even then there was no looseness of the coil on the core. This one has WAY more than 35 thou movement. more like an 1/8 inch.
And oddly, when swapped with a known good one. miss fire went away. Nothing else was changed. Didn't even remove distributor cap.
So. Not clear at what point looseness is to loose. But this one wobbles around like a **** in a sock.
And miss fires under load.
Old Oct 30, 2021 | 08:24 PM
ebbnflow's Avatar
ebbnflow
Curious about your fairly new HEI dist. How much (in USD) does it sell for in USA ?
Old Oct 30, 2021 | 08:41 PM
LightningBrett's Avatar
LightningBrett
I've seen lots of loose coils like yours, new and used. Being loose does not mean it is bad.
Old Oct 30, 2021 | 09:01 PM
TimAT's Avatar
TimAT
Might be a good question for 69427.. He might know
Old Oct 31, 2021 | 01:37 AM
4-vettes's Avatar
4-vettes
In answer to how much does a replacement distributor cost in U.S. dollars. This is a Proform distributor, purchased through Summit Racing. Advertised as a performance distributor. these are the same people making the G.M. replacement distributor from what I read about 2 years ago.
You can go to Summit's site and check a price. I wouldn't bother. It's anything but a performance distributor. I would not recommend it. Check my thread on getting this thing dialed in. And then the coil fails.
Wouldn't buy another one if it was just 1 dollar.
Old Oct 31, 2021 | 04:00 PM
ebbnflow's Avatar
ebbnflow
Oh, I didn't want one. Just a reference point for what may have drawn buyer to a good buy.
I'd just refurb an old GM dist.
Old Oct 31, 2021 | 04:27 PM
dmaxx3500's Avatar
dmaxx3500
dont waste your time over-thinking this,,they are all loose [from 40+ years ago] and they work just fine
just use it,put the coil back in the cap and install it
