Transmission upper mounting bolts
Old Oct 25, 2021 | 12:24 PM
riverwabbit703's Avatar
riverwabbit703
Default Transmission upper mounting bolts
Hey fellas, I am still going over the 1981 vette I bought last week. This forum has so far helped me fix the loose steering column issue and front wheel metal scraping sound and I am grateful to you all.
Now this morning while i was checking the transmission (th350) mounting bolts, bottom mounting bolts to crossmembers are in tight but one of the upper mounting bolt that bolts to the aluminum transmission case is loose. I believe it’s stripped. Time to get helicoil kit correct? But in meanwhile, how bad that upper one bolt that is loose on the transmission case affect transmission? Will it shake bad/clunk when shifting gears?
thanks
Old Oct 25, 2021 | 07:54 PM
Mooser's Avatar
Mooser
If your not careful it'll try to strip the other bolt threads or worse, break the ear off. (at least I think the th350 has an ear for the vettes
Can you get a longer bolt up through the stripped side and put a washer/nut on it until you can "fix" it
M
Old Oct 26, 2021 | 04:46 PM
riverwabbit703
Bought m 10, 1.25 with few lock washers and it actually tightened the upper mounting bracket better than stock. Thanks to all.
To Transmission upper mounting bolts
